There you go.
Basil
>High resin content and sunlight.
Here in the south there were a lot of old homes that had stood for years without termites eating them up. Two things made that so, high resin content and sunlight. The old homes were built out of what the old timers called "old original heart pine". That's the type of heart pine that, if ol' Norm ran a board of it accross anything in his shop, he'd have to break out the kerosene and start cleaning his blades. I've pushed up cutoff "heart pine" stumps that have been in the ground well over 150 years and they're still solid. (as a side note here) I tried to make a pin from a root one of those stumps. It was a tight grain swirls of beautiful red and yellow grain patterns. Turned like it was 'wax' and the least amount of heat from sanding it and the sandpaper and wood blank both gummed up and turned black. Not to mention anytime you 'freshen' up this wood it bleeds resin.
Back to subject. Most of the better old homes were built high off the ground on pillars, plenty of fresh air and sunshine under them. Under the houses, the dirt was usually dry as a powder keg. Of course over the years these old homes had some remodeling done to them with southern yellow pine of a ever lower and lower grade. Then came the time that they started "underpinning" these older homes for purposes of heating and 'looks'. Well, then began the termite problems. The termites had dark moist areas to work. They eat up all the newer wood in the homes but they wouldn't touch, or couldn't touch, the older "heart pine".
Back in the 60's when I did carpenter work, it was interesting to gut one of those old homes. When you got them gutted, you could stand back and look at the different methods of construction, wood prep. and quality of materials. It was almost like watching a movie or something on the progression of time. If the home was real old, it might have logs with some hand hewn timbers and split boards. Then you might see some pit sawn stuff, later circle sawmill rough cut, on down to the modern lumber. If there was termite damage, we pulled the modern lumber out by the fist full. The real old wood would still be solid as a rock and the little bit later wood we might have to remove the sapwood and maybe scab some new lumber to it but the newer wood, it usually all had to come out.
