DC fittings
Doug Ridley
>What do you use to connect a 4" hose to a 4" S&D PVC pipe. The hose won't go over or into the pipe. The things I have tried so far are pretty sad looking. Suggestions please.
Doug
DC fittings
Doug Ridley
Doug
Re: DC fittings
Randy Johnson Connersville IN
>Any of the many vendors who sell plastic DC fittings sell an adaptor that will solve your problem.
The Red Green solution will work too but it doesn't look as good.
Re: DC fittings
Doug Ridley
>Thanks. But what is the Red Green Solution?
What I've done before..
Jim Rahbe, Bedford Texas
>Doug,
Cut a piece of the S&D pipe about 8 inches long. Cut a thin slot all the way from top to bottom. Make the slot big enough to allow the cut piece to just fit inside the uncut S&D pipe. The hose should also fit over the cut piece. With about 4�of the cut piece inside the hose and the 4� inside the S&D pipe, you can then apply the �Red Green� solution, which of course is duct tape.
Jim R.
Re: DC fittings
>Duct Tape
Re: What I've done before..
Doug Ridley
>Thanks. That'll work and that's what I'll do. Now, why do you call duct tape the Red Green solution. Inquiring minds want to know.
>He does EVERYTHING with duct tape. Even the gutters on his house are held on with duct tape. You obviously have never seen the show. There is always a segment called "Handyman's Corner" where he makes some weird contraption from various odds and ends. It is always held together with duct tape. I don't remember what it was, but once he used a propane tank on one of the projects and he solved the problem of joining left hand and right hand threads together with.....duct tape.
The show centers around members of the Opossum Lodge. The motto is:
"When all else fails, play dead."
Dan Donaldson
>It would not be obvious if you have never seen it. There is a character named Red Green that has a tv show in which he builds and fixes almost anything with duct tape. It is a comedy and some of the episodes are hilarious.
Red Green *LINK*
Dave Peebles Lyons, Ohio!
>Hi Doug,
Here is an example of Red using some Duct tape. :)
Dave
Red Green
Re: Red Green
Doug Ridley
>Okay so I have never heard of Red Green. Thanks to all for enlightening me. (I guess).
And thanks for the suggestion on splitting the PVC.
Re: Red Green
del schisler
>i watch red green all the time on bell express 91 canada satellite Also some more that are good corner gas also good watching Not much to do with wood working tho
Re: DC fittings
Dave Paine
>My own solution is either to put the 4 in flex hose inside a 4 in S&D fitting (elbow, coupler, etc), or else in the bell end of a section of S&D pipe.
The fitting is the easiest, since only get 1 bell end for a 10ft length of pipe.
Alternate is a special adapter. More expensive than the S&D fitting.
Re: DC fittings
>I used the bell End when it worked for me and when I wanted the pipe to be smaller I sawed slots in it around the perimeter of the open end until it was a series of fingers. Then I could squeeze it down to size with a hose clamp. You can also do remarkable things with a heat gun (maybe a hairdryer?) and carefully applied heat from a torch or torches.
I did the best I could to keep the make female orientation so that the flow was toward the DC.
Re: Red Green
Theresa K
>You really owe it to yourself to watch Red Green! It's on PBS channels here. I bought my husband a Tshirt from Red Green, and it came packaged up as Duct tape :) The wrinkles never came out!
One of my favorites...
John in NM
>Though I generally prefer hose clamps to duct tape.
John in Calgary
>Red Green is a canadian icon (I also understand he didn't get past thanksgiving in first year of engineering due to his predilection for beer and the great quantities drank in Waterloo during Octoberfest, too bad, he probably would have been a very 'innovative' engineer), well known for his creative use of duct tape.
John
