Deck Ledger Board - DUH!
Dan M
>Hello. Been a while since I was here.
I believe this is a no brainer, but here goes. I am rebuilding a deck and intended on using as much of the original framing as possible as it is in pretty good shape. I got a good look at the ledger board. I have a typical vinyl sided home with that 1/2" thick insulation all over it. When they built my house and deck, they installed (nailed) the 2 x 10 ledger board OVER the foam. I am thinking this is BAD BAD. Believe right way is to lag screw it into the rim joist in a location where in inside floor joist is located. They did not use flashing either, but that is easy to remedy. All in favor of me pulling off all the deck joists (14 of them) and reinstalling the ledger board right on the rim joist with lag screws, say Aye, the rest say Nay! Thanks!
Dan M.
