how to end trim 26" wide panel?
Bill Tindall, E.TN
>This table I am building for daughter is bigger than my equipment. I need to end trim the 26" wide top sections (extension table). In the past I have more or less free handed such a cut on the table saw and then cleaned up the cut by various means. There has to be a better way. Any sage advice on this task?
Re: how to end trim 26" wide panel?
Dale Lenz
Re: Circle saw...
Dale Lenz
>with straight & hefty board used as a straight edge. One way of many. As they say pick your poison.
Michael Bush
>Seems to me that a jig or frame that would do this (without the plunge cutting, which isn't necessary for this job) could be knocked together from a piece of plywood and some scraps.
doug f, san clemente, ca
>Maybe too simple, but how about a straight edge or a straight piece of stock and a router with new spiral bit. In two or three passes this would make a nice clean edge.
Just a thought.
Doug
I used to do this all the time
>Use a fence or template guide and rout that edge straight and true. I think it gets you closer to the desired result with very little time investment.
Re: I used to do this all the time
AZ in Colorado Springs
>I'd use the router with a shop made edge guide (unless you already own a factory made edge guide).
John McGaw
>Sure. And someone who really really really tried could do the job with a decent handsaw. But getting a sharp clean unsplintered cut is something the Festool excels at and after its pass down the track just a touch of sandpaper would finish it up. Besides, every woodworker deserves an excuse to buy an new toy every now and then. ;-)
mike from american sycamore
>this is a fairly common practice here at the school. We use a clamp-n-tool guide and a router with a large base plate to help keep the router flat and up against the fence. I use a 1/2" solid carbide two flute spiral up cut router bit for a baby butt smooth edge cut. Precision large panel cutting is time consuming this way and I hope that the woodshop fairies will bring me a large sliding table saw that would make this procedure so easy!
Mike
>I've done it both ways that have been mentioned. You could put a good sharp blade on your circular saw and use a straight edge, but I get better results with a router. (I suspect the base on my circular saw is not exactly parallel to the blade, used it for years framing houses and one too many bad knocks.) I put the straight edge on so the cut is very slightly proud of what I want and make two or three passes to cut off the scrap. Then I move the straight edge a few thousands of an inch and make a cleanup pass. The cleanup pass is probably a waste of time, but that's just me.
I also made a wide sled for my TS. The runners stick out way past the base. It is somewhat unwieldy and if I can I enlist some help, particularly if the panel is large. On larger panels it is better for me to take the tool to the wood (router) than to take the wood to the tool (TS).
PS Router bit.....
>I recently spent a considerable amount of time repairing some hard wood flooring where walls had been moved and floor added. I got spiral bits at Harbor Freight. I had ruined several expensive bits hitting nails. The HF bits were really too long and had at least 1 1/2" cutting depth. They were quarter inch diameter. I did not want to chuck them deeper into the collet because I was afraid the cutting edges would scar the inside of the collet. There was considerable whip. Had to take light passes, and used the little step stop thing on the router to do it in three passes. In spite of the cheap bits that were too long, it did a good job. OTOH, I an sure a 1/2" solid carbide spiral bit (mentioned above) would be a joy to use compared to a 1/4" bit, but either will do the job. Some of it depends on whether the cut end your panel will show or go into a frame.
Zero clearance edge guide
Tim Greif - West of Chicago
>I'd use the same jig I use for cutting sheet goods. Make yourself a zero clearance edge guide out of 1/4-inch hardboard and 3/4-inch plywood. You just need a known true edge of the plywood (like the factory edge) to register the circular saw base against. I screwed a slightly oversize piece of hardboard to the plywood, then make a cut with the circular saw to trim the hardboard to make the zero clearance edge.
Make sure you make the plywood part wide enough to allow clamping and still allow the saw to pass by without interference. In my case, that was 5-inches. This jig makes a very handy way to cut sheet goods. I've even used it to cut very thin slices off the bottom of doors for clearance.
Re: how to end trim 26" wide panel?------WebKitFor
Samuel Brooks------WebKitFormBoundaryFpwd7Jr6mGYA+
>All of the other options are great options, but if you just want to make one quick cut try the following.
Measure the offset from the left side of your table saw to the blade. Use that as your offset and clamp a straight edge to the bottom of your panel with a couple of clamps. Then cut your panel with the straight edge riding up against the left side of your saws top.
I have used my 4' level as a straight edge for this. I would also recommend that you check the left side of your table saw to make sure that it is square to the blade. If for some reason it is not, then you can clamp something to it and shim that to get the side square.
------WebKitFormBoundaryFpwd7Jr6mGYA+dyV
With A Router
>Hello Bill,
When I do it, all it takes is a long straight board/straight edge clamp, and my hand held router equipped with a pattern bit with a top bearing. I clamp the straight edge to the underside of the work and make a couple passes.
George
Fred Davis
>That is a good idea assuming your Unisaw wasn't made by the same bunch that did mine .
Forunately the Powermatic 66 I have would do this idea perfectly .
This would be a good time and excuse for Bill to either make a vertical panel saw or buy one , that tool takes all of the guess work out of trimming large panels.
FredD
thanks for all the excellent ideas
Bill Tindall, E.TN
JerryBurns
>Skil 66 and 40 tooth carbide blade and a 4 foot stright edge just did it yesterday I have cut down 2" thick tops with this set up with no chip out the worm drives turn slower then a sidewinder. but if you bind the cut it will rip your arm off
