Replacing Chair Cane
Ben Ragusa, S Jersey
>Good Morning All,
I received an order last night from my best customer. This one sounds important, so I cannot simply add it to the bottom of the list. She has requested that I replace the cane seats and backs on a set of dining chairs we will then put to use. They are of the spline type. I have never done this before, so I am asking for your advice in getting started. I have seen a booklet that some vendors sell and was wondering if you think it would be useful, or if you may recommend some other source of instruction. Supplies and materials seem to be readily available from the usual sources, but again, if you have any thoughts on the subject, I would be grateful to hear them.
Re: Replacing Chair Cane
Bob Powers
>Several years ago, I rebuilt a pretty little chair that I found on its way to the dump. I decided to re-cane it myself. I bought the tools, supplies, etc., for about $30 and went to work. I found the project to be much more difficult than I would have thought. In short, I was attempting a project requiring skill and knowledge that I didn't have. I called a lady from Yellow Pages, she came, picked up the chair, did the job beautifully, returned the chair, and gave me a bill for $40. Never again will I try caning.
>Good Morning Ben,
I've done sheet cane (and hand cane) replacement numerous times. Sheet cane isn't all that difficult but initial instructional knowledge is always beneficial. Buy the booklet offered and read it. Also bear in mind as you place your order that there are various sizes and styles of sheet cane and various spline widths. It is very important to use the correct spline width, and to insure proper clean out of the groove when the old cane is removed. Should you want to discuss the details further, e-mail me off line. I can talk you through it via telephone, if you'd like.
George
Doug Ridley
>As George says, get the book and be sure to order the right size spline. Clean out the old grooves, cut a piece about 2" larger on all sides ,glue and tap in the splines, trim off the excess with a razor knife and you are done. There really isn't a lot to it and anybody can do it. Measure the holes in the old cane to determine what size cane to order.
Doug
One thing you should NOT do.....
Tim Greif - West of Chicago
>The one thing you should NOT do is use PVA (yellow woodworkers) glue to put this back together. At least not if you ever want to be able to redo the chairs again. I made that mistake about 25 years ago on some bentwood ice cream chairs that were relatively inexpensive, so I didn't feel so bad about throwing them out in the end. But trying to remove the spline and cane sheet from that groove with PVA glue was next to impossible. If I were to do it again, I'd use hide glue which will soften with water to allow removal.
As others have said, read about it. Make some small wedges to pin the cane initially in the groove while you install the spline. And soak the cane sheet in hot water in the bathtub before you start. That's another neat trick about tightening sheet cane when it develops a little stretch. Lay a real hot wet washcloth on the cane for a while. As it dries, it will tighten up like a drum.
Re: One thing you should NOT do.....
R. Gryder
>Tim,
I have learned a lot from LOML who does chair caning on a regular basis. If a chair has been caned with yellow woodworkers glue, soak the groove with vinegar. Slow but effective. R.
R. Gryder
>Ben,
Mrs. G. has caned many, many chairs. She obtains cane and other material from Peerless Rattan in Plainwell MI. The company is run by Ed and Cindy Hammond. Nice folks. They will help with instructions, etc.
Addresses are;
Peerless Rattan
687 Miller Road
Plainwell MI 49080
1 877 611 2263
sales@peerlessrattan.com
Thanks, Roy
>I'll add this to my sources file. I haven't done much caning, but I'd like to learn about it. Thanks for the resource.
Ellis Walentine, Host
Re: Thanks, Roy
Joe Grittani
>For anyone interested in learning to weave cane as opposed to using sheet cane, Cornell University Extension Service has one of the finest little instruction manuals I've seen Very Cheap. I've had mine since the mid 70s and I think I paid $.50 for it then. I'm sure it's gone up but still reasonable. I used to cane a lot. Thankfully those days are past.
Joe Grittani
Bill White
>Don't forget to add some glycerine to the water as you soak the cane. Slows the drying time.
Bill
the link  *LINK*
Dan Donaldson
Peerless Rattan
