oxalic acid
oxalic acid
oxalic acid
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Is oxalic acid a bleach-- or, technically, is it something else?
Re: oxalic acid
Jason Roehl in Lafayette, IN
Re: oxalic acid
>It's...an acid. "Bleach"--usually shortened from "chlorine bleach" is basic/caustic--other end of the pH spectrum. Oxalic acid generally isn't sold in very high concentrations, but is often called "wood bleach" or a "brightener".
Jason
Re: oxalic acid
Re: oxalic acid
Howard Acheson
>The word "bleach" is a general term meaning the removal of color from any substance. Some bleaches are clorine but there are many other chemicals that remove color. Oxalic acid is an acid that removes the color caused by minerals by reaction with the chemicals that cause the discoloration.
Another woodworking bleach is a two chemical treatment that bleaches the natural color from wood.
All are bleaches in that they remove color. There are hundreds of chemicals that remove color. Even the sun will remove color from certain woods and in a technical sense, it is a bleach.
Re: oxalic acid
A bleach is a bleach
>Oxalic acid is a strong bleach. It is particularly effective on black stains on woods high in tannic acid that have come into contact with iron. It makes them vanish instantly.
Recently, I used an oxalic acid solution to scrub away some organic stains on a concrete pool deck. The solution not only eliminated the stains, it bleached the concrete to a lighter, grayish color, wherever it came into contact. So, it definitely has bleaching capabilities.
I have not tried it on my laundry. Too much room for disaster. :-)
Re: oxalic acid
Re: oxalic acid
Fred Davis
>I used Oxalic acid frequently in Leather work to bleach tooling leather to a uniform color before working it .
It also will roughen your hands if you didn't wash them right away , but I never got a chemical burn from it.
FredD
Re: oxalic acid
Organic acid - chelating agent.
>Oxalic acid is more appropriately an organic acid. It has the ability to "bleach" because it has two carbonyl (C=O) functional groups and it also is quite strong for an organic acid. It has a pKA of ~1.3 for the first carbonyl as opposed to acetic acid which has a pKA of about 2.2.
Oxalic acid can form compounds with various metals quite easily - especially iron, calcium, magnesium, etc. It can "leech" metal stains out of wood and other materials because it has this ability to form these relatively insoluble compounds. Of course the relative acidity doesn't hurt! It is literally dissolving the metals.
Other organic acids can act to chelate metals - tartaric acid, citric acid, ascorbic acid. They are not as strong of acids though they are better chelators.
My $0.02.
Re: oxalic acid
Re: Organic acid - chelating agent.
Bill White
>Sure will remove water stains. Used it on a dishwasher interior once. Looked like new after the treatment.
Bill
Re: oxalic acid
Fred Davis
>One of the few tips I gave my wife that stuck with her was on dishwashers.
Put two , (she does) 500 MG Vitamin C capsules in with every wash.
DW will look and smell like new as long as you do this.
If you have a heavy Calcium Cabonate build up in the DW , run a 1/2 cup of White Vinegar though Rinse cycle, same results , looks like new.
FredD
