Leaking toilet question? (OT)
>I have an off brand toilet that has an unusual flapper in it. The flapper is hard plastic and has a disk on the business end that has a sort of cone on the under side that closes into the drain port in the toilet tank. On the opposite end, there is a little cup about the size of a film canister. The canister has an open top and a small hole in the bottom. When you lift the flapper the little cup is full of water and holds the flapper up until the water drains out of the cup.
The one that came with the toilet lasted something like twenty years. It was a real scavenger hunt to find a replacement. When I finally found it at a specialty plumbing supply house, it cost nearly twenty bucks. Now after about two years, the toilet is wasting water again. I cannot detect any defect in either component. The underside of the flapper is smooth and so it the rim of the seat. I tried putting a little Vaseline on both parts and that seemed to help for a few days. Now it is leaking again. The water level in the tank drops until the filler valve refills it. Water is not leaking onto the floor, but through the bowl and down the drain.
The soft rubber ring the stand pipe flush valve are mounted in has become degraded to the point that if you touch it you get sooty black finger tips. I am trying to figure out if somehow the water is leaking through the rubber and into the bowl or if it is just the flapper. Any Suggestions? Just replace the flapper again?
