non psa sand paper?
non psa sand paper?
non psa sand paper?
mike from american sycamore
>I can remember my father using a tube of "Sticky stuff" to glue on sandpaper to his metal disc for sanding. I have a need to glue some non psa paper to a round sanding disc. Is this sticky in a tube still available? What do you recommend to glue sand paper to a metal disc?
thanks,
Mike
Re: non psa sand paper?
Bruce, a MN Galoot
>a bunch of years ago I bought a bottle of adhesive designed to glue a sandpaper disc to a metal platen, just as you want. IIRC, I got it at Sears (that was before I knew better). However, it was a real bear to remove the paper.
Bruce
Re: non psa sand paper? *LINK*
John McGaw
>Way back when, nearly 50 years ago, in shop class we used a stick adhesive that required melting by applying heat to the metal disk. I don't know if that exists any more but there is another sort that is still being sold.
http://www.3m.com/product/information/Feathering-Disc-Adhesive.html
>Good Afternoon MIKE,
I use Elmer's spray adhesive, just enough to do the job. What paper I can't peel off, I can intimidate with a razor blade.
George
GalenV in Iowa
>Bruce
Thanks for the reminder.
I imagine I can throw this away after keeping for about 30 years.
I think the last disc I mounted was using rubber cement from the craft store. It seemed to be the same stuff as the old Sears.
I'm sure there is a specific product but I never use what NORMAL people are supposed to use.
Believe it or not the glue is still liquid!
Galen
>thanks for great information as usual and thanks for even going to all the trouble of taking a picture.
Mike
I use 3M 90 spray adhesive
Bill Tindall, E.TN
>It is a little more grabby than necessary, but it will work for your application.
