Finishing
Bart Leetch
>After rubbing down with steel-wool a surface finished with Poly Urethane can I spray lacquer over it?
Finishing
Bart Leetch
Why?
Bill Tindall, E.TN
>probably not but as in all such cases, test concept. Why would you want to add a less hard, less resistant finish over a urethane?
Re: Why?
Bart Leetch
>Thanks for the answer.
Re: Why?
Fred Davis
>Poly being a synthtic Varnish of sorts , don't be surprised if Lacquer blisters it.
FredD
Re: Finishing
Howard Acheson
>I would not overcoat an oil based finish with a lacquer if the finish was less than a year old. The chemicals in lacquer thinner are very aggressive and can react with fresh oil based finishes.
While lacquer is a quite a bit harder finish than oil based poly, it is inferior in some other areas. Why are you considering doing it?
Re: Why?
Howard Acheson
What do you mean by a "synthetic"? Poly is a standard oil based varnish where some urethane resin has been used or added to the alkyd resin that is used to make most varnishes. Any varnish is a mixture of a resin (alkyd, phenolic, urethane) and a drying oil (linseed, tung, soya). The two are mixed and then heated until a new compound is formed called varnish
