Bosch Tools
mdclor
>I have been a happy user of Bosch tools for the last several years, but today that came to an end. First a little background: I dropped a drill (clearly my fault) and needed to have it serviced. The servicing company didn't know the meaning of the word "service" so I needed to get a regional manager involved and was more than satisfied with the outcome. Next, my router wouldn't turn on, so I had it serviced and all was fine for 2-3 months, then the switch "died" again, so I had it repaired again. Somewhere along the way my ROS sheared off the bolt that holds the sanding pad onto the actual unit. I replaced the bolt and had the sander up and running in no time. Today, the bolt came out of the ROS, probably just vibrated loose, so I replaced and tightened it. That lasted for about a minute. I have decided that I will not purchase another Bosch tool. Has anyone else had 2 tools "die" in the same day? I should also mention that I do not "lean on" my tools to make them work "better".
I stepped onto a very slippery slope and ordered a Festool 6" ROS, something I never thought I would do. I am looking at options for a replacement router. I think the Festool prices are outrageous, but if that is what it takes for reliability, so be it. Cry once....
My reason for mentioning all this is that I have been a Bosch proponent a number of times on this site and I want to set the record straight so as to not steer any in the wrong direction in the future.
Rant mode off,
Merle
