living and working wood in the desert?
mike from american sycamore
>Anyone live in the desert here? What is working wood like? Special care? Wood movement a problem? Moving furniture from the desert to other areas?
thanks,
Mike
thanks,
Mike
Dry, dry and more dry
Lee Grindinger
>While technically not a desert Montana had similar humidity, 90 f with 12% RH was not unusual. I lived in SLC for the early part of my career which definitely was a desert but easier to deal with because the heat necessitated the use of coolers and swamp coolers raised the humidity to decent levels.
But, in Montana it was different. I remember bringing wheelbarrows of snow into the shop to dump on the floor in the wintertime to try to get the humidity up. I'd often see my hygrometer in the low teens or lower. When a commission was heading to a more humid place I'd dump wheel barrows full of snow on the floor in the winter, wet the floor in the summer..., introduce moisture anyway I could. When a commission was local I'd do nothing.
Ask any questions you'd like, I'm happy to answer.
Lee
Finishing is Different
Ron in Sterling, CT
>I live in New England, but spend my winters in Arizona. The lower humidity has a noticeable effect on finishing. Varnishes and urethanes dry so much quicker and to me it seems that I can get a smoother coating. Also, I have noticed that glues begin to set up faster (based on a couple of bad experiences). My 2 cents worth.
Ron
Re: living and working wood in the desert?
Jesse Cloud
>Way different. I live in New Mexico. We get about 11 inches of precip a year (most places back East are in the ballpark of 40 a year). Humidity is usually below 10 per cent.
This means there are few trees growing out here, cottonwoods (not useful for fine woodworking) and junipers. Lumber comes from a long way off and is expensive, selection is limited compared to back East. Mailorder lumber makes sense, even with shipping costs if you do not need to select pieces carefully for grain. You do need to take extra care to bring your wood to a stable moisture content.
As posted above, stuff dries quickly here. Glue sets much faster, some of us add a little water (about 10 per cent) to our titebond. Brushing or padding shellac is intense.
Since most of us use swamp coolers for cooling (based on evaporation), interiors usually run about 30 per cent humidity in the summers. The so-called "monsoon season" brings humidity, but not much rain... so there is great variation in humidity. But nothing that good design can't handle.
You can get a portable swamp cooler for your shop if this is a problem.
One very positive thing - no rust!
So, are you moving to the desert? Whereabouts?
paul in AZ------WebKitFormBoundary+isMX5X2paiDYC5e
>I'm in Tempe Arizona. This time of year the humidity runs around 2% relative. for us it gets up to around 25% at times and that is high (for here). Humidity in the house always runs higher than outside just as the reverse is true in centrally heated or cooled houses elsewhere.
I have noticed no special problems. Glue soaks in and sets up faster and as noted finishes dry very quickly. I do try to let lumber sit around a while 'caus much of it is not particularly dry when I get it.
Wide pieces subject to more expansion have to have space for expansion as a consideration. But then I've never had something go to a house in Florida's humidity so I don't know about those extremes. Things that wound up in the north and northeast have not misbehaved.
I've not had any trouble with cracking of furniture I made and brought with me from far more humid climates I lived in before. I have a 19th C. English desk that has not cracked or split in this much dryer climate.
A glorious benefit is that I can put a cherry piece out into our intense sunlight on my patio for a couple of days to develop a wonderful coloration.
I will add to the melting snow comment: get a bedroom vaporizer or two if you want to raise humidity in the shop. I have one but never use it.
>I have an uncle in Yucca Valley CA. I am considering some different options for me. I believe I am going through the"change of Life" or something! I am 53 years old and divorced after all these years. I am searching to find myself again.
Mike
Winnemucca Lynn
>Here in northern Nevada, the annual precip. is about 8 iinches. I get exasperated with people who say they get seasonal wood movement because the summer is more humid. It doesn't happen for me. Wood is a lot more difficult to get. And living in a town of about 8,000, and about an hour from other towns, there are no turning clubs and very few other people who share your interests.
Lynn
Re: living and working wood in the desert?------We
>Far be it from me to tell you what to do BUT I can say that the things I regret the most are things i didn't do and not the many stupid things i did. Mistakes relating to people are much harder to undo than those that can be fixed by throwing a few dollars at them.
I have 20 more years of mistake-making on you.
------WebKitFormBoundaryL6+xoS8yy6snfNYK
I live there ...
Mike.Farinella
>smack dab between Death Valley, Ca. and Las Vegas, Nv. Humidity here is usually in the mid-teens. If I buy mail order, the woods sits stickered for about 5 - 6 months. If I buy from my Las Vegas suppplier, it sits about three months (I don't have a moisture meter nor is the shop cooled by evaporation). I have NEVER had a problem with wood shrinkage.
Regards.
paul woolson
>I was in PHX for 10 years. If you have the time/patience to let wood season properly, it's actually beneficial to build in a drier climate.
Reasoning: if the drying occurs when the lumber is in board form, you won't get much shrinking when it is in finished form. (pretty hard to dry out from 2% RH)
Also, you'll have better luck if you ship your goods to other climates. If I built in PHX and shipped to someplace like Nashville where it's pretty wet, things would swell a bit but that causes no harm. If I were building in Nashville and shipped to PHX, I'd be pretty worried about cracking.
Jesse Cloud
>Desert is a good place to find yourself. Easier to focus when things are simpler. You can see a long way and that makes most folks humble.
Try Albuquerque. Lots of woodworkers. First rate Fine Woodworking program at Santa Fe community college. Got a Woodworker's Supply store and a Woodcraft. The Albuquerque Woodworker's Association is very active, as are the turners and carvers. With all the rich folk and movie stars in Santa Fe, there's a market for high end furniture, but a lot of competition to provide it.
And more than 300 days a year of sunshine.
