We value your privacy.
being a tree person and from Oklahoma ,I hope you can answer this. I planted a Caltapa Tree two years ago. It is doing well it is about 7' tall. About 5' from the ground it has branched out with three main stems. My question, Is Caltapa a central leader tree? Should I prune off two and encourage a single leader untill the tree is more mature?
I'm an arborist and I love catalpa trees! The smell of their flowers is feint but wonderful!
The current pruning style that arborists are modeling is presented by Dr. Ed Gilman. His webpage will teach you all you'll need to know about pruning.
When anyone is pruning the main thing to remember is that the leaves are the food factory. If leaves are cut off there will be less starches made and less bulk. If the goal is to bulk up a limb/trunk leave the leaves. If you want to subordinate or reduce the growth prune off the food factories. Sometimes removing part of a limb is the best practice. This slows down the branch growth but still allows the food factories to make starches.
Read up on Dr. Alex Shigo's work too. Shigo is the father of modern arborculture.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
Guest
Re: OT Dale Lentz tree Question
>John, It may depend on how YOU want the mature tree to look more than improving the tree shape.
I visit the Arkansas champion Catalpa every few years when I happen to be passing near. It what I fondly call a walk-up tree, in that the branches are low, and the lumps on the trunk make for easy climbing. Its lower branches start out about head high, and reach out 40' or more.
Last time I climbed it, I had a friend take a photo of me sitting on one of the lower limbs. While sitting there, I could not help but notice that the pith center of that branch was exposed on the surface. The wood of these trees is highly decay resistant, and the sapwood layer is usually thin. I don't know if a hail storm knocked all of the bark off the top of the branches, or if kids climbing it killed the living part of those lower branches.
>If all three branches come off the same place you'll want to end up with only one, single stem. Decide which will be your permanent leader. Cut back the other two by about 1/3 at the beginning of the dormant season or late summer. This will freeze-frame their growth but they'll still produce starches and add to the bulk/diameter of the main stem.
If you cut off too much growth you'll end up with a spindly trunk/branch. Also, making too many cuts at one place in the stem has the same effect as girdling, you're severing the cambium which leads to decline and large amounts of decay.
The leader that you chose as the main stem will grow in diameter in comparison to the other two. In a couple of years the diameter ratio will be better and you'll cut off one or both.
Remember, all of the sawlogs that we see all had limbs going all of the way to the ground. At some time the tree shed most of them to make a single, clear stem. Leaving a few branches for the first few years is perfectly good nursery/silviculture practice.
If the third stem is bending off at a funky angle you can splint it in place. I've done this a few times and it works perfectly. Take a piece of 1 5/8 or 1 3/4 diameter hemlock or ??? closet rod or handrail and use it as the splint. Take duct tape and make 4-5 passes around the splint and tree to hold it in place. Even if you forget to take off the tape it will degrade naturally in a few years and fall off. The tape will not girdle the trunk like any other method. NEVER use wire in hose to guy a tree...no different than dental floss left on your finger tip!
