Finish for Locust outdoor furniture?
Joanne - near Dansville, NY
>I'm building a adirodack chair, ottoman & side table out of locust and I was wondering if I should apply a finish or leave it unfinished? What kind of finish should I use if I need a finish?
Thank your for your comments.
Joanne
Re: Finish for Locust outdoor furniture?
Jesper, Denmark
Jesper, Denmark
>Assuming this is black locust, Robinia Pseudoacacia, you do not need any finish. It becomes a beautiful light grey that you can keep up with a stiff brush and water.
Re: It is Black Locust- NM
Jesper, Denmark
Re:Then your problem is solved, except......
Jesper, Denmark
>Use bronze or stainless fasteners.
If you have not worked Locust before, you will also get a few surprises - internal stress in boards are common, so binding on the table saw is a potential. The planing can be difficult, as you will experience some wild grain.
If you use screws, dip the screw in linseed oil before you screw them in - otherwise you will not get them out again. Pre-drilling is a must.
The locust is very strong and heavy, so if you use plans designed for pine, you can lighten up on the thickness a bit.
