Tenon size
Tenon size
Tenon size
JoeW in Detroit, MI
>I'm in the process of repairing a bed. The post was broken off the rest of the head board. I'm planning on installing floating tenons to make the repair. The post is 2.5 inches and I'm going to use 3/8-inch thick tenons that are 3 inches wide. How long should the tenons be? Should I have equal tenon length in both the post and headboard rails or should the rail side of the tenon be longer? I have seen formuls for calculating tenon length but as usual I can't locate the info at the moment.
Re: Tenon size
Re: Tenon size
Ed Mulligan, Cape Cod
>Those joints are not stressed much. Tenon length of 3/4" should be fine. There's no reason to make the tenon lengths unequal. Mortise depth should be 7/8" to allow for glue and crud.
Re: Tenon size
Thanks
JoeW in Detroit, MI
