Question on TS switch?
>I have a Delta/Rockwell from the early 70's. Early in it's life the motor burned up and I replaced it with a Dayton 2 hp TEFC motor. The saw has been 100% reliable. The other day when I flipped the switch (a little toggle switch, not a magnetic one) the blade sort of pulsed and turned less than a revolution and then nothing. I slipped the switch again and it took off. This happened two or three times. Then it went back to being it's old reliable self.
The questions: Was this likely to be the switch or the motor? If (when) it happens again, how do I sort it out?
