THE WOODRAT IS BACK!
drill press guard
drill press guard
drill press guard
Kai
>I was just told by OHSA that I need a guard for my drill press. The good news is that I can build my own, the bad news is I have no real idea's that seem to work. Anyone have an ideas they would be willing to share? Thanks, Kai
Re: drill press guard
Phil Joines Krum,Tx
>Isn't it interesting that they tell you have to do all these things but won't make any sugestions on what meets their requirements?
What are you guarding against?
>Covering the belts? Keeping your hands/head/hair out of the spinning bit? A little more detail would help us all offer conflicting advice.
Randy Johnson Connersville IN
>I can�t imagine what a drill press guard looks like - I don�t think I�ve ever seen one on any of many, many drill presses I�ve seen.
It reminds me of an incident when I was a maintenance man at a nursing home. There were two �managers� in one small department. I was responsible for the actual maintenance and the other manager, another maintenance man, was responsible for life safety and most of the paperwork. It worked out well. He didn�t really know how to DO anything. Prior to my working there they usually called an outside contractor for any plumbing or electrical problems, but he was a wiz at paperwork while I�m weak in that department.
Anyway, one day he conducted a tour with an �expert� from an insurance company who informed him (and through him, me) that the tool rest on my fifty dollar bench grinder was unsafe. Why? Because it was not set at ninety degrees to the wheel. I tried to explain to Tim that the sixty degrees it was set at was 1000% safer for the task it had last been used for than ninety degrees would be, but I was talking to someone as ignorant on the subject as the �expert�. The subject was dropped after I said I wish I could have been there so I could have called the �expert� a moron to his face and maybe even taught him something I learned in seventh grade shop class.
Re: What are you guarding against?
Fred Davis
>This is typical Government Big Brother-ism, along the lines of ,back in the seventies OSHA,sent out to contractors a communique stating "that in the near future Chainsaws will be required to have Guards"
Never happened for obvious reasons.
Never in my experience has OSHA required machinery operators to demonstrate at least a passing acquaintance with Power tools before they are allowed to use them.
This probably would be construed as a violation of their Civil rights.
Even the Carpenters Union well before I retired, sent out Apprentices to job sitesand more often then not were handed a Skilsaw and saw cord and told to go help this or that Journeyman.
Hauled more then one to the hospital.
FredD
Re: drill press guard *LINK*
GalenV in Iowa
>A lot of the time what will be approved is what the individual inspector had in mind. They finally decided our big radial arm drill press and twelve foot metal lathe were not adaptable to any type of guard they could come up with. At least the operator no longer sat on a 5 gallon bucket on the drill press table! Our smaller 14x40 metal lathe ended up with just a lexan shield that was only in place to protect the operator in line with the chip field and easily flipped out of the way for setting up the pieces.
Small drill presses too had only a chip shield and did not even cover the chuck.
They do make better telescoping shields now but like our work they were not practical due to the shapes being drilled.
Not much help I know but then we just kept putting the pressure on the inspector to show us what they needed and he could not.
As I recall in a long history I think one man got cut by trying to pull a metal curl off the drill bit with pliers and it whipped his hand GOOD. (Well cut badly).
Galen
Commercial shields
Fred Davis
Kai
>to be a little more specific, I need a guard to cover the chuck and the bit. Apparently someone in Nevada has lost a finger to a spinning chuck and several people have had hair torn out. Makes me wonder if any of them actually read the manual for the press. I have found several after market guards but $100 or more seems a bit much for a what I'm seeing. I am trying to get clarification on if it needs to go completely around the chuck or if it can just be in front where the operator stands. Funny how the OSHA guys are always around to tell us how to be safe but never around to answer follow up questions.
Hamish
>Morning Kai,
I have a drill press with a chuck guard fitted on it. It is a spring actuated flip-up, semi-circular, perspex guard, which is fitted around the boss or ring above where the chuck slides into, on the drill body. The idea is that it can be easily flipped down to cover the revolving chuck, thus avoiding the dangers that others have mentioned.
When I first bought the drill press, I used it a lot. It is easy to flip down but over time, the perspex has gradually gone cloudy making it nearly impossible to see through it. So now it gets left in the upright position.
In use, I have found that it is not necessary while drilling wood, as the shavings thrown out break off at the drill bit causing no harm. But, as I'm sure most of you have found, drilling metal is quite different. Long strands of hot metal spin off about the bit, making safety glasses or a guard a sensible precaution.
I should add that my drill press is fitted with a keyless chuck, so no flying chuck keys there and the off and on switch is fitted in front just above the guard, making it easy to turn off with the press of your flat hand or your forehead if a problem arrises and your hands are full.
I will try and see if I can post a photo of it, something I have not tried to do yet on WC.
Cheers, Hamish.
Al Stokka - Cambridge, Iowa
>Kai,
It has been years (evidenced by the 1991 edition note) since I was involved with OSHA regulation but,...
29 CFR 1910 (ed.1991) 213(i)2:
"Boring bits should be provided with a guard that will enclose all [my emphasis] portions of the bit and chuck above the material being worked."
You should be able to get a copy of the regulations free from either OSHA or the agency in your State charged with enforcing the regulations.
Perhaps a two or three piece guard that would telescope into itself as the hole is being drilled and expand as the drill bit is withdrawn from the workpiece?
Al
Marv....... Northern California Lake Co.
>Ok, Al, now lets do a milling machine, a lathe, a bandsaw, an ax, to mention a few. Maybe we should figure out how to put a guard on a handsaw. You can cut yersilf on one O tham thangs!
I remember the first OSHA notification I got when I was in business during the early 70,s. They even demanded that we increase the number of urinals in the men's restroom. The inspectors were worse than the IRS agents. Like the gustapo, they goose stomped, unannounced into our building and wrote us up on every stupid little thing they could find. Their goal was to not leave until they at least fined us enough to pay for their weeks work. I use the word "work" very loosely. They have the authority to file charges against not only the owner of the company, but also the supervisors, even jail terms.
It's no wonder we can't compete with overseas manufacturing with all the regulations, such as drill press gaurds, plus a million other restrictions, all of which cost a fortune. Then of course we have the almighty EPA to contend with.
We have two kinds of people in our country, people who actually work and those who don't. The non-doers have become the majority. The situation is not going to improve. We are well on our way to being a third world country. Greed and stupidity is the driving force. It always starts at the top and cascades down through the masses. It's all about the money. We finally managed to greed ourselves into an economic disaster. And we are too stupid to stop the process. We are beyond the point of no return.
Marv
Paul Kristofek
>Since I have worked extensively with OSHA- a suggestion. Build a 2" concrete box completely around the drill press, and include a room sensor swith to power off when entering the room, and for added safety, include a floor matt switch which will shut the press off when an operator stands in front of the machine. Have the inspector sign off on this.
Alex Grigoriev
>Or build a wooden box around the DP and pour concrete to the top. You can remove the wooden box after concrete sets.
