tung oil
tung oil
tung oil
joek
>I'm working on an Oak ( I think ) dinner table. It is about 100 years old. It had been "Antiqued" and I am removing the antique finish with a Refinesher. I was planning on using a "tung Oil" to complete the finish. Just curious if anyone may have any experience in that area ?
Re: tung oil
Re: tung oil
Howard Acheson
>What do you mean by "tung oil"? Are you referring to real, 100%, pure tung oil or one of the faux "Tung Oil Finishes"?
Another question, are you removing the complete finish or are you using one of the "refinisher" products that claim to leave the patina? Are you planning to re-stain?
Depending on your answers, there are a number of choices and options.
Re: tung oil
Re: tung oil
joek
>I am using Formby's Refinisher and it is taking it to what looks to me as the original (or close to it) finish. I was planning on using Formby's Tung Oil.
Thanks
Re: tung oil
Re: tung oil
Howard Acheson
>It's OK to use the Formby Tung Oil Finish. Forby Tung Oil Finish is a varnish pure and simple. Read the label carefully and it will say that it is a varnish. It contains no real tung oil. The closest it comes to tung oil is its name.
That said, it's a pretty good, light colored varnish. It's made with an alkyd resin and soya oil with a dab of tung oil. When heated together the resin and oils change into a new compound called varnish. Because it's a varnish it can be applied over and other finish as long as the surface is clean of contaminates and has been lightly, but thoroughly, scuff sanded with 320 paper.
Re: tung oil
Re: tung oil
joek
>thanks for the info
