Turpentine or mineral spirits
Bill Hammond, Oregon Coast
>In the past (far too long ago) I have used Varnish, BLO and Turpentine, equal parts, as a finish. I like the hands on feel of this finish. I see where a lot of people, or so it seems, use mineral spirits in place of the turpentine. I am wondering just how this affects the finish? It seems to me that it would dry faster and perhaps smell less. For a current project I am trying the mineral spirits, on Myrtle Wood. Just wondering if I am going to regret it. Any one have hands on experience with the two and care to comment on the differences?
Bill
Re: Turpentine or mineral spirits
>Turpentine is "distilled resin". As such it contains mostly terpene derivatives. Things like alpha-pinene, limonene, beta-pinene and camphene. These are small molecules with one or more double bonds and usually a pleasant aroma. They are often cyclic. Lots of alpha-pinene in some turpentines. C10 is the typical carbon number.
Mineral spirits are a mixture of aliphatic (straight chain) hydrocarbons (C7 to C12) with some cyclic aromatics and cyclic compounds mixed in. No regular structure. The distillation range is much broader - a lot of stuff boiling (and evaporating) at lower temperatures.
Chicago Bob
>I too like this finish. In my experience it makes no difference since either eventualy evaporates and essentially is a solvent or thinner for the other two components. Usually, mineral spirits is cheaper and slower evaporating although turpentine smells better to me. A higher ratio of the solvent in the mixture slows down the build rate but I am guessing that this also accelerates cure.
I also believe but haven't tried it yet that you could "tint" this mixture (solvent soluble tints) to aquire a more "amber" or whatever finish.
Good luck, but you will not need it because it is hard to mess this finish up which suits me to a "T".
Regards
Bob
Curious About The Advantage
David Yoho
>I'm asking this because I'm curious as to why folks prefer these "brew their own" finishes as opposed to one already formulated and sold by manufacturers.
It seems to me that in the case of the mentioned mixture above, a product like Waterlox would serve as well or better. It has the oil, varnish, driers, resins, and solvent already mixed to an exact formulation that works.
I've often wondered what the advantage, if any, is of a home brew over an existing over-the-counter product. While the various home brews seem to work, are they actually better than store-bought? I wouldn't think they're any less expensive. So, again, I am curious as to the attraction.
David
Re: Curious About The Advantage
Fred Davis
>I agree one hundred percent David , while I took Chemistry in High school ,nothing in that prepared me to compete with a finish manufacturers R&D department staffed with coating specialist Chemists.
While I know a few people who brew their own beer, I occasionally buy Heineken's which I am reasonably sure is not green or otherwise contaminated.
FredD
Not really sure...
>In many ways I have to agree with you, hoever it's really no different from thinning the lacquer to get the consistency you want or mixing stain or dye for the color. I am taking good products made with the help of chemists, R&D departments and all that, and mixing them to what I want. If I knew of a commercial product that was the same or very similar and at a price, then I would use that. I can increase the turpentine or MS to make a very thin oil finish that I think soaks in further and drys rather fast. At the end I can use only the varnish for a harder finish if that is what I want. Usually I don't, I like the soft feel of the finish and the fact that it's easy to repair. I usually use it without any stain, if I need color I'll add it in the early coats, oil based colorants or oil paints (art supply stores) mix in easily and interesting shades are possible. By it's self on dark woods it's all that is necessary for a rich look and feel.
Oh, and it's so easy to use too.
Bill
Re: And I would agree, but
Glenn Madsen near San Francisco
>here in the great state to your immediate south, we get buggered up formulas at times. A mix as you describe for me, maybe 6 years ago, ended up taking months to dry to the point at which I could wax it and put the dresser to use. Same thing for the headboard, although that was a different wood.
Like Fred says, for me, the last chemistry class was 1970. And I decided that economics looked a lot more interesting.
Now I use shellac, thinned Waterlox and McCloskey's varnishes, or something similar. There are a few others in the finish shelf, but most haven't been opened in a while.
5 or 6 kinds of wax, though. What's up with that?
Re: Not really sure...
jerry mayfield
>What you have described was called "Danish Oil" by the finish companies about 1/3 BLO,1/3 polyurethane varnish and 1/3 solvent(usually mineral spirits). What most call Danish Oil today is over 70% solvent-Look at Watco"s msds. If you like an oil/varnish finish you can mix your your own very easily,and at less cost. The mixture can be varied easily, for a harder finish add more varnish etc. You do not need to be a chemist to mix oil and varnish.
Regards
Jerry
BilWil
>I think the difference is the smell. Lots of people prefer one, i.e. turps or ms, over the other. I prefer the smell of turps. As to why mix you own, well in my case I prefer using 25% tung oil, 25% marine varnish, 50% turps and a tiny bit of japan drier. Then if I want I can add oil compatable colors to get the exact shade I want. I get to choose satin, semi-gloss or gloss for the varnish, and I can vary the proportions as I build the finish. When I buy the mix off the shelf, Watco or Waterlox or any of the others I don't have the same freedoms - I do use the mixes when I don't need the versitility mixing my own offers.
Re: Oil based finish thinners
Howard Acheson
>There are a number of thinners that can be used to thin an oil based paint or finish. Turpentine is a natural product that has been used for years. It is made from the sap of pine trees. There is not "standard" for what turpentine consists of and it can be somewhat variable in performance. Compared to mineral spirits, it can be a more aggressive solvent/thinner. And, of course, it has a strong, long lasting distinctive odor.
There are a number of petroleum based thinner/solvents. Naphtha and mineral spirits are the two most common but kerosene has sometimes been used in the past. Then there is paint thinner, which is generally a deodorized mineral spirits and may have some other "conditioners" added to improve the finish flow out.
As far as volatility (speed of evaporation), naphtha will flash off the fastest, followed by mineral spirits and then by paint thinner.
Any of these thinners can be used. The petroleum thinners are much less variable than turpentine.
Finally, oil based finishes dry/cure in two steps. First the thinner/solvents evaporate and the finish feels dry to the touch (tack free). However, the next step is the actual curing of the finish. The cure occurs as oxygen mixes with the varnish and the varnish changes composition into a hard and strongly adhering film. This curing process takes 3-4 weeks to be completed. A finish is quite soft until it has fully cured. The point of this is that the choice of thinner only affects the initial evaporative step. It has no affect on the speed of the curing process.
Wipe-On Finishes
Howard Acheson
>Here is something I put together a number of years ago regarding wipe on finishes
There are two "true" oils used in finishing. One is linseed oil which comes from flax seeds. The second is tung oil Which comes from a nut tree that originally grew in China. Both are called drying oils although neither really fully dries and becomes hard. They form a sort of rubbery deposit just below the surface of the wood. The primary use of both is in manufacturing oil based finishes.
A product that is a true tung oil will have a label that says either "pure" or "100%". If it doesn't say that on the label, IT ISN'T TRUE TUNG OIL. Forget about all the other baloney and look for one of those two words if you want to use a true tung oil. If the label contains any other chemicals, except a thinner, you are not getting a true tung oil. Real tung oil has acquired a cachet in the past twenty years that seems to elevate it to some type of magic potion. In fact, as a finish, it does not offer anything much different than linseed oil. In spite of the hype, is not significantly more water resistant than linseed oil--both are lousy--nor is it any more durable. Used alone both are fairly inferior "finishes". About the only difference is that tung oil is slightly less amber than linseed oil but it also is slightly less effective at "popping" the grain. By most measures, it is not significantly different from linseed oil.
"Tung Oil Finish" is a marketing expression for products that the manufacturer thinks will give you a finish like the finish you get from a true tung oil. These "Tung Oil Finishes" may or may not contain some true tung oil, but most do not contain any true tung oil. Their only claim to the use of the word "tung" is that they claim to give the appearance of finish that results from true tung oil. You're buying a "faux" tung oil finish. Similarly, "Danish Oil" is a marketing expression for an finish that gives the appearance of the Scandinavian furniture of the 1950'a and 60's. In many cases it's virtually the same as the "Tung Oil Finish".
There are two types of "tung oil finishes". One is mixture of varnish, boiled linseed oil and mineral spirits (called an oil/varnish mixture). The exact mixtures are proprietary (more oil means a softer finish--More varnish means more protection and durability). Some manufacturers add a dollop of drier to speed up the drying. If you want make your own, mix equal parts of boiled linseed oil, varnish and mineral spirits which will make a nice finish. This same mixture is frequently also called "Danish Oil". It closely mimics a true oil finish but the addition of the varnish resins gives it more durability and protection. These finishes are designed to be a complete finishing system. They are not intended to be overcoated with a film finish. When you do so, you are destroying the look and feel of the finish. For the most part, "Tung Oil Finsih" and "Danish Oil" are identical. They are both oil/varnish mixtures.
Here are some oil/varnish mixtures:(*)
Deft Danish Oil
General Finishes' Seal a Cell
Behlen Danish Oil
Maloof Finish (contains pure tung oil and linseed oil)
Behr Scandinavian Tung Oil Finish
Minwax Tung Oil Finish
Minwax Antique Oil Finish
Velvit Oil
Watco Danish Oil
Liberon Finishing Oil ((contains pure tung oil and linseed oil)
McCloskey Tung Oil Finish (contains pure tung oil, no linseed oil)
The second "tung oil finish" is one made from varnish and mineral spirits. The approximate ratio is 1:1. This is really just a thinned varnish just like the stuff sold as "wiping varnish". When one two or three coats are applied, it also mimics the finish produced by a true oil but it is harder than the oil/varnish above because it does not have as much oil. It is slightly more protective than the oil/varnish type or tung oil finish. For all intents and purposes it is a varnish finish.
Here are some thinned varnishes:(*)
Minway Wiping Varnish
Watco Wiping Varnish
Formby's Tung Oil Finish
Zar Wipe-on Tung Oil
Val-Oil
Hope's Tung Oil Varnish
Gillespie Tung Oil
Waterlox Original Sealer/Finish
General Finishes' Arm R Seal
Jasco Tung Oil
Here is one that is a polymerized linseed oil.(*)
Tried&True Danish Oil.
(*) Courtesy Bob Flexner and some personal information.
One way to tell whether the product is an oil/varnish or a wiping varnish is to read the application instructions. Oil/varnishes are applied, then given some time to set, then wiped dry. Wiping varnish products are wiped on an left to dry (no wiping off).
Finally, I'm not disparaging any of these products. In fact, they are a more protective and durable finish than any pure oil finish. When you make them yourself, you control what's in them. They are what they are and can give you a very nice close-to-the-wood finish when properly applied and not overcoated with a film finish.
Perhaps I can add some clarity
Michael Dresdner
>As was mentioned, turpentine is a natural product derived from plants. As such, it contains more components and varies more than petroleum based derivatives such as naphtha, mineral spirits and deodorized mineral spirits, all of which are specifically crafted by us to be more consistent than that which is crafted by nature.
Naphta, minerals spirits (also called paint thinner), and deodorized mineral spirits are basically the same soup of primarily alkanes or paraffins. If this soup has a flash point below 100 degrees F, it is called naphtha. If above, it is called mineral spirits or paint thinner, two terms used interchangeably by the industry.
Lower flash point means faster evaporation, so yes, naphtha evaporates faster than the other thinners. Deodorized mineral spirits, also called Stoddard solvent, is a soup like the others, but one that contains almost exclusively isoparaffins, a sub group of alkanes that tends to smell less.
There are many different formulas for these soups depending on what they are to solvate and how fast one wants them to dry. Finish formulators can choose from a wide variety based on these characteristics, but if you buy it in paint or home stores, you are limited to what the manufacturer decides to offer in those venues. Thus, other than the fact that naphtha is the fastest, the others may vary widely in speed depending on the formulation. As was said, all can be used to thin most oil based finishes.
Perhaps most important is what Howard said; solvent evaporation is only the first step in a two step curing process. Which solvent you use will not affect the film you eventually get once it is cured by oxygen polymerization, the means by which oils cure.
Jim Dillon
>Bill,
JL nicely described the differences between the "turpentines" and common "mineral spirits". Since none of the major constituents of either class contain active reactive groups (other than a double bond or possible ketone group (memory fading here)), the primary difference important to me would be volatility and smell (and cost). Generally speaking, I think either would likely work for ordinary wiping-on or brush work, but a spraying application may be more critical.
Jim (who does like the smell of turpentine ;-))
