6x6 treated post
6x6 treated post
6x6 treated post
Lynn Reedy , Soddy Daisy Tennessee
>I have a large back porch that is covered and I have a problem with the 6x6 post that support the roof. These treated post have twist approxmately 1.5 inch out of square. I remember seeing the same thing on a home improvment show once but I don't remember how it was cured. Removing these post and replacing them is not possible. Does anyone know a fix?
Re: 6x6 treated post
Kneale Brownson..Awaiting return to CO snows
>No "FIX". You could wrap them in a box of 1X8s.
>I think Kneal is right. Unless you can replace the post, I can not imagine any way to straighten or untwist it. As a Home Inspector I see them frequently. Essentially every 4 x 4 and 6 x 6 I see has the path of the tree in it, meaning they are mostly juvenile wood and have a strong tendency to warp. Some say they twist because of stresses built into the tree by the fact that the sun tracts across the sky. Whatever the reason, they do that.
In addition to what Kneal said, I would be sure it has thoroughly dried and finished twisting. If they are are really twisted, 1 x 8's may not be enough. It might be possible to trim some of the offending wood off the corners to make the posts fit inside the new boxes.
My experience is that the posts twist. What I observe is that some twist a little and some a lot more, but the majority twist some. Being longer or taller magnifies the problem.
