REAL MILK PAINT
Fixing rotted Exterior doors questions.
>I want to fix some rotted exterior French doors. There are four panels and some are seriously rotted at the bottom. In some cases I could easily insert a knife more than half way through. The inner sides look pretty good, slightly stained, but sound.
I was thinking I would take a router and route away about fifty percent of the thickness of the bottom rails and see what I find. If they are fairly sound at that level I will treat them with a rot killer (BoraCare), a wood hardener, and then replace any unsound wood left with bondo. Then glue in a piece of decay resistant wood.
Once the rail is replaced, I would work on the stiles in a similar fashion.
My question is how to replace the strength of the doors. I am assuming the M&T joints will be compromised. How about drilling in through the edge of the stiles and inserting long dowels?
Any help would be appreciated. Anyone know how long it takes Boracare to dry enough to add the wood hardener, bondo and glue? I am considering doing the work on site or bringing them back to my shop. Can anyone clue me in further. Seems like a better shop project than field project, except that the shop and house are 150 miles apart.
Re: Fixing rotted Exterior doors questions.
definitely a shop project... *LINK*
John in NM
>In that its not something to rush through in a single day if you've never done it before. Might take a short time, but if you run into problems it'd be much better to be able to take a break and not worry about finishing by evening.
I would also avoid bondo at all costs, as I've not found that it adheres especially well to wood in an outdoor environment.
I've not used the product below, but as far as I know, its the stuff.
http://www.smithandcompany.org/
