Finishing Cherry
Finishing Cherry
Finishing Cherry
Carlos Clarke
>I'm getting ready to finish the drawers to my kitchen cabinets.
My wife likes the look of the 'honey spice' cherry cabinets she
saw at Home Depot. To me it looks like cherry with an amber
finish, it isn't pink but it isn't dark.
I don't work much with cherry. A lingerie chest that I built for her I finished with a spar varnish with UV inhibitors. That didn't darken a lot until a couple of years ago when she put it in direct sunlight.
The kitchen gets a lot of sunlight. How do kitchen manufacturers
keep cherry from getting very dark and still let the grain show?
Re: Finishing Cherry
>Furniture manufacturers cheat. Quite often the wood is not even cherry. But they often use a colored finish. Real cherry, regardless of UV protection will do what cherry does...darken. How dark? Depends on the tree it came from!
Tom
>Good Afternoon Casrlos,
Tommy is quite correct. It depends on the tree. Rather than risk your wife's displeasure, why not use another hardwood and stain/dye it to her specifications?. Birch can look like cherry. Personally, I like sunburned cherry and think it is almost a crime to use stain on top.
George
Different Wood
>Since George mentioned Birch as an alternative, you might consider Red Birch which is what I used in my new kitchen. This will not darken and the finish is straight acrylic lacquer over a sealer. No stain, dye, or pigmenting in use.
Tony - Memphis
>Funny, they called our kitchen cabinets cherry, but they are actually maple with lots of stain on top. Its not even real cherry color, its that cordovan red that some folks call cherry. I've seen poplar used as a substitute for cherry. It is very affordable too. I've stained it a couple of times and had real good luck getting the color I was after. It is a very pleasant wood to work as well. I used birch once and it was nice too. Only one issue and that was some blotching when I stained it. Gel stain might help with that. Cherry blotches too, and its very different from piece to piece.
Tony
Yonak
>Carlos, it sounds like you may already have your cabinets made so considering another type of wood is out of the question.
Personally, I don't like to stain cherry at all but, as Thomas alludes to, I use cherry from the same "batch", figuring I have a better chance that, if not from the same tree, maybe at least it's from the same area. It can be a crap shoot, for sure, but board matching before cutting is necessary. (All this is, likely, superfluous if you already have your cabinets made.)
My experience is that cherry will darken whether it's in direct light or not. I put stain on some cherry when it was inlaid into red oak once. At the start the two woods were about the same contrast but now, after four years, the cherry has become quite dark. ..Bottom line for me : I don't like to stain cherry.
Re: Finishing Cherry: Thanks
Carlos Clarke
>Thanks for the responses.
I don't work with cherry much but I don't like staining it either.
The cabinets are built. The face frames and drawer fronts are done.
I think I'm going to finish them with a UV inhibiting varnish
to slow down the darkening. Then when they get too dark for my
wife's taste I can use that as an excuse to replace the frames
and drawers with some nicely figured exotics. It won't be hard to
do because the face frames are only screwed to the cabinets and
the drawer fronts screwed to the drawers.
Thanks again.
