Adjustable Roller Stands?
Tom MacGregor
>I want to get a pair of adjustable roller stands for in/outfeed. Harbor Freight has them at $20 ea. but I question the quality of their stuff. Can anyone recommend some that are a good value for the price?
Re: Adjustable Roller Stands?
Jesper, Denmark
Jesper, Denmark
>For 20 Bucks each, how can you go wrong?
Re: Adjustable Roller Stands? *LINK*
Ed Mulligan, Cape Cod
>Save your money. Don't buy this design from anyone. The roller, unless perfectly perpendicular to the direction of stock travel, tends to move the stock out of line. A piece of melamine with a coat of paste wax works much better than rollers IME.
The Lee Valley stand costs much more but it addresses the failings of the old design and is well worth the price. There's a fine adjustment for height or level. The wheels can be bypassed.
Lee Valley Roller Stand
quality not much an issue
Bill Tindall, E.TN
>A roller stand doesn't demand much "quality" of construction but it does require weight and that is what the import stuff usually provides. Cylindrical rollers are problematic for out feed on a table saw as they can guide lumber off course if not exactly oriented. I replaced the cylindrical rollers on the stand I bought with ball rollers and all is well.
>The rollers do tend to direct the stock one way or the other. I have a homemade set. I actually use the rollers to direct the stock toward the fence. I turn the rollers slightly and they help keep the outfeed end snug to the fence. Not very scientific. I just give them a whack so that they are a few degrees out of alignment. I guess I could wax the rollers to reduce the effect.
And another thing.......
>Thanks for the thought, I finally understand the concept of the big ball bearing ones and the one from Lee Valley. OTOH, it seems to me that in either case narrow stock might get tangled up between the bearings or casters and get directed somewhere undesirable. I tried the slick panel for a while. Worked fine, but in my shop any flat solid surface has something sitting on it after about a minute and I would have to move it before I could use the TS.
Howard Norman
>I use the Lee Valley model as an outfeed table for my table saw. I have several of the roller models that I use elsewhere, usually at the miter saw.
Tom Rex in TX
>They don't stay up.
Tip very easy.
Fred Davis
>This may not be the concept your dealing with , but I use a ShopFox brand four legged , height adjustable roller stand five feet long and 16" wide for a outfeed table at the jointer.
FredD
Simple Rollers and a Work Mate
>Good Evening Tom,
I bought a single roller at HF a few years ago and devised a mountable bracket for it. It sits in the jaws of a Work Mate, clamped at the correct height for my TS. Works like a champ. It must have cost $5 or so. I received a set of roller stands from HD one Christmas, and promptly returned that junk to Santa Clause.
George
Tim in SE Michingan
>Don't do it. I bought one of their stands thinking the same thing. Its in the dump now. It wouldn't stand up and one of the legs broke. You get what you pay for with this product.
