A55 Smoothing Plane
5 mm Barrel Hinge Problem
G Deavers
>I am making some small decorative boxes and am trying to use some 5mm brass barrel hinges. I cannot seem to get the alignment on the back of the box right.
What is the best method to drill and install these hinges on a lid and box?
Thank you in advance.
Greg
Re: 5 mm Barrel Hinge Problem
Lee Schierer - McKean, PA
>I've made several boxes with these hinges and I make the holes first and then cut the bevels. I clamp the two pieces together and do the layout and then use a drill press and brad point bit to drill pilot holes for the final size bits. Then I cut the bevels with my router. As I install the hinges after finishing, I put some super glue in teh holes before inserting the hinges. This tends to lock the hinges in place.
Lee
G Deavers
>Hello Lee,
Thanks for your answer. I am having trouble accurately drilling the 5mm holes in the back of the box. Still working that one out.
I cannot find anything on the net concerning "how to".
do I bevel the lid back to clear the opening, and could you suggest how much how much? The lid on my boxes are about 1/2 and the walls are around 3/8"
Make a drilling jig
>If I read you right, your mating holes don't line up perfectly, and the lid ends up askew. For aligning holes I like to use a technique made popular by James Krenov for doweling his cases together. Make a jig out of an accurately cut scrap of wood, with your holes drilled at whatever spacing you want. Attach edges to this template that reference on the back edge and one corner of your box. Clamp it to the lid and the walls in turn and drill to whatever depth with a hand-held drill, using the jig as a drill bushing to locate the bit and keep it square to the work.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>What Ellis suggested should work, but you can't get too far from the back edge without it binding, and a small chamfer will give clearance against that if you already have drilled it.
>As I said before, drill the holes before beveling the edges. Then once the holes are drilled, you want to bevel the edge at 45 degrees until the edge of the bevel is exactly centered on the holes. (Half the hole is in the flat and half is in the 45 degree bevel) You need to bevel both pieces. I've attached a photo of three sets of hinges mounted in a jewelry box I made.
Lee
Thank you Gentlemen!
G Deavers
>Once again you have proved yourselves!
I made a small jig similar to the one Ellis suggested - except I put the post piece in the ID location so that I could set the jig post inside the box and clamp it to the back "hoping it would not move". I have to do 3 boxes the same size.
I used a 5mm brad point drill and still somehow I miss-drilled the right hand hole in the back of the box with my drill press.
I now must plug that one and re-drill it in the center....
Thank you once again for your assistance!
Greg Deavers
