We value your privacy.
>The fan on my Dell dimension Is extremely loud on occasion and this morning when I booted up it wasn't running at all, then it took off and is running now. Are these generic? And can you buy them at a place like Best Buy?
>There are several standard sizes, so measure yours or bring it to the store. Best Buy might have it. Radio Shack probably would. If not, there are plenty of on-line sources like www.tigerdirect.com.
The cheap ones run on bushings which wear out in time. Ball bearing fans are only a couple dollars more and last much longer.
>Could be just a dirt build up on the fan blades. I have a Dimension and when the fan starts acting up a good shot of compressed air will fix the problem.
>Is this a case fan, a cpu fan, or a power supply fan? Replacing or repairing a power supply fan is a job for someone who has done it before and replacing the cpu fan might require require also replacing the thermal goop between the heat sink and the cpu, depending on how the fan is mounted.
>The Dells I've worked on have had a proprietary cooling fan and shroud mounted at the rear of the case. The single fan does double duty as a case cooling fan and CPU cooler. The green plastic shroud and fan are one unit, which directs the air flow across the CPU heat sink and out the rear of the case.
The CPU fan on my HP went through a few noisy spells; once to the point I was looking to replace the fan. However, after several days of noisy operation, it started to sound like normal and has been fine since. I keep my case interior clean and whenever blowing with compressed air, I use a small dowel to keep the fan blades from spinning. I killed several fans before I started keeping the blade from spinning during cleaning and haven't had an issue since.
