How To Build A T&G Bulkhead Door?
Pete in NVa
>I was asked to build a replacement for an exterior tongue and groove bulkhead door - the kind that lies on a sloped wooden frame and used to be common for exterior basement entry. I copied the design of its predecessor, using 1x6 pine T&G boards screwed to a 1x4 pine Z frame. I also edge glued the T&G boards, based on a "how-to" article I read in Fine Homebuilding. Overall door dimension was 37 wide x 57 long. Painted the whole thing and installed it with hinges on one side. It looked fine on installation.
After 1 month, the T&G bords buckled, stripping out from its screws, and the door width had expanded considerably. It was clearly a moisture induced problem. I hadn't allowed much room for expansion, thinking that the Z frame screws would contain movement, since no other example I had seen had made any allowance for movement, e.g. expansion slots for screws. I was clearly wrong.
But I still don't know how the old timers did it. If you don't edge glue the T&G boards and try to leave expansion room in all the grooves, the door will leak in the rain. If you screw the boards to the Z frame, as I did, they will bust out the screws with moisture changes. Yet I've never seen a single installation where expansion slots in the Z frame were used to accommodate wood movement.
If any of you have built a door like this, I'd appreciate any tips. Certainly, using a more stable wood, like cedar, would help, but I don't think that's the whole story. I could epoxy the T&G boards to the Z frame, but I fear that might cause the door to rip itself apart from the stresses of moisture change. What am I missing, short of going to a metal bulkhead?
