cheating
cheating
cheating
Fred Davis
>Ken Cully a older then me woodworker , sent this and I wonder how wide spread it is , though this takes place in Canada.
----- Original Message -----
To: undisclosed recipients:
Sent: Friday, May 29, 2009 1:25 PM
Subject: Fw: cheating at the gas pumps ...NOT A JOKE
> PLEASE READ!!!!!!!!!!!!!!!
> ________________________________
> Cheating at the gas pumps (PRINT OUT YOUR RECEIPTS!!!)
> This email was sent to me by a friend whose cousin is the Ridgetown,
> Ont. fire captain.
> This is true. It happened to them three weeks ago somewhere in
> Ridgetown on our way to Kingston. The pump should have totaled @
> $38.00 (and change).
> When
> the receipt was printed, and she checked it was $ 47.00 (and change).
> She got mad, went inside the store, asked for a calculator and let
> them do the math. They refunded her. She told them that if they cheat,
> they had better make it right. Normally, her husband would skip
> printing the receipt.. Not her
> We saw on the news the other night that this is happening everywhere.
> Brian pumped exactly one liter of gas. The price did not match the
> cost of one liter. It was higher. He went inside and complained, got
> a refund.
> There is also a number on each pump that you can call and complain..
> This is a true story, so read it carefully.
> On March 24, 2009, I stopped at a gas station in Chatham. My truck's
> gas gauge was on 1/4 of a tank. I use the regular grade, which was
> priced at
> $0.885 per liter. When my tank is at this point, it takes somewhere
> around 45 liters to fill it up.
> When the pump showed 45 liters had been pumped, I began to slow it
> down.
> Then, to my surprise, it went to 50, then 55. I even looked under my
> truck to see if it was being spilled. It was not. Then it showed 60
> liters on the pump. It stopped at 62 liters. This was very strange
> to me, since my truck has only a 65 liter tank. I went on my way a
> little confused, then on the evening news I heard a report that
> 1 out of 10 gas stations had calibrated their pumps to show more gas
> had been pumped than a person actually got.
> Here is how to check a pump to see if you are getting the right
> amount:
> Whichever grade you are using, put EXACTLY 10 LITERS in your tank,
> then look at the dollar amount. If the dollar amount is not EXACTLY 10
> times the price of the fuel you have chosen, then the pumps are
> rigged.
> In my case, as I said, the mid-grade was $0.885 per liter; my dollar
> amount for 10 liters should have been $8.85 . I wish I had checked the
> pump. It doesn't matter where you pump gas, please check the 10 liter
> price. If you do find a station that is cheating, contact the MTO, and
> direct your comments to the Commissioner, the info is on the gas
> pumps.
> Please don't delete this until you have sent it to all people in your
> address book. We need to put a stop to this outrageous cheating of
> customers. The gas companies are making enough profits at honest
> rates.
One at a time or all at once? Get updates from your friends in one place.
Create a cool, new character for your Windows Live� Messenger. Check it out
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.5.339 / Virus Database: 270.12.43/2138 - Release Date: 05/27/09 18:21:00
Re: cheating
Dale Lenz
Re: Seems to me...
Dale Lenz
>Just because 10 liter/gal must equal 10x the volume price does not indicate you are getting what you pay for. You could be paying for 10 units of gas and possible only getting 9 units, rigged pumps. I usually check my gas mileage at every fill up. Lets hope this problem is not wide spread.
Re: cheating
Re: cheating *LINK*
Bob Entwisle in NJ
>Here's a little more info:
http://www.snopes.com/politics/gasoline/cheating.asp
Re: cheating
Re: cheating
Fred Davis
>Bob, sounds like a urban legend has struck again ;-((
Ordinarily I wouldn't have forwarded this , but it rang true and so it seems Ken and I were both fooled
I too wondered about where the Weights and Measures people were ,
FredD
Re: cheating
The first time . . .
steve mackay
>I've filled up my truck more than once and with the way prices have fluctuated in recent memory I, pretty much, know how much for a tank at any given price. That said I have a pretty hard time think'n that an individual store owner is skulking out in the wee hours, opening Chevron's pumping unit, adjusting all the calibrated electronics and then falsifying all kinds of documents for a pretty good chance at jail time for an assortment of crimes and violations. Sorry, my conspiracy paranoia (and it IS vast !) only goes so far.
Re: cheating
Re: cheating
Bill White
>My local Wally World sells in gallons only (hee hee!)
That incredibly miserable attempt at humor aside, I DO check regularly.
Bill
Re: cheating
Re: cheating
Jerry Nicholson
>I had a situation once where the pump indicated that I had put about 5 gallons too much in my 1974 FIAT Spider. The tank was in the trunk and there was gasoline sloshing around all over the place because a plastic vapor separator valve had failed. Fixed the problem with a rubber band but I had to punch a hole in the trunk floor to let the gasoline out.
Jerry
Re: cheating
Meter calibration
Jay Lombardo
>I serviced gasoline dispensing systems for many years and it is very difficult to cheat the public. We used to calibrate them with a 5 gallon test can that is certified by the state department of weights and measures. Then the state would go around and check them before placing the sticker you see on the pump. They are very particular about the measurements. The can reads in cu. in. over or under "0" Zero being exactly 5 gallons. The tolerances are +/- 5 cu. in. but if the whole station is -5 he will tag the whole joint. The meters would typically be +1 or 2 on one dispenser and - 1 or 2 on another. This is not where the station owners cheat you but where some of them do cheat (AND THEY DO) is another whole discussion.
Jay
