deck footings
mike mcnerney
>Hi, I'm wondering what are the possible techniques for decj footings on a nearly flat roof? Someone said styrofoam with 2xstock on top & then run your joist on that. Should the styro be tared in?
Mike McNerney, Ottawa
deck footings
mike mcnerney
Terminology
>I'm not understanding your question, Mike. What is your idea of a footing? Are you building a deck on this flat roof? If so, why not just put 2x3 sleepers on the existing roof in line with the roof joists and deck over that? If you want the deck to be level, make tapered joists out of pressure treated 2x4s.
Ellis Walentine, Host
Re: Terminology
mike mcnerney
>Ellis,
I haven't done one for a few years & haven't looked at this particular job yet so I don't know how high I have to build it up but it is in Toronto & they get snow that can sit on a flat roof for a while so let's just say that the door to this roof is 12" above the roof & they don't want to step down that far, so we have to put some joist down maybe 2 x 6 ? I guess I thought that sleepers directly on
a roof done in the most basic of roll type roofing might damage the roof? So I thought something soft like styro might be good/
thanks
Mike
Re: Terminology
>Mike, I am not an expert on this and I am hundreds of miles south of you, near Richmond, VA. As a Home Inspector, my opinion is this is a disaster in the making. It is very difficult to do what you want to do and you are already behind the curve. If you have ordinary roll roofing, it is the most temporary of the commonly available roofing materials. Locally, it lasts about ten years. (Maybe longer for you, it is hot and humid here.)
The problems you face are that the roofing must be accessible for repair and replacement. Deck type floors tend to allow debris to sift through. The debris holds water and turns into compost. The wet material accelerates the decay of the roofing. You should not walk on the roof any more than necessary for maintenance. So, it is very difficult to construct a floor over a roof, especially "on the cheap". I suppose you could take the approach that you set them up to fail simultaneously. Use materials for the deck that will last about as long as the roofing. Then, when the time comes, you tear both off and replace them.
Don't think I would use styrofoam in this application. It breaks down in sunlight. There are mats available that are laid over flat roofs as walkways. They appear to be heavy rubber mats. I suppose they are heavy so they won't blow away.
On the occasions I have done this, I made the floor up out of a series of "pallets" that sat in place on the roof so they could be lifted out and the roof cleaned or replaced. You may have another whole series of problems in regard to the railings.
Re: Terminology
Fred Davis
>I agree with Barry for all of the reasons he stated and some he didn't.
The job is inviting you to a really poor ending.
Why is there a door onto a roof with only roll Roofing in the first place?
If you still want to risk it , insist the owner has been informed that it is a bad idea in the first place and you would need him to acknowlegde that in writing in the second place and ifhe doesn't like the 12" step down , include a wood step to a deck formed in 48 " or 32" liftout sections.
Like Barry noted , the railing is a whole other story. Over the years I avoided those type of jobs like the plague as a contractor.
FredD
Thinking about something similar...
>My shop is on a bank barn foundation. When I rebuilt the shop in '99 after the fire, I added a 12 x 40 foundation and concrete deck out back at the lower level and built a sturdy flat roof above it (2"/12' pitch), with a patio door from the shop floor opening onto the roof. My plan, if I can ever afford it, is to put a deck on top of the roof, similar to what you have in mind. I have a pile of pressure-treated 2x6s that I will taper to level the deck surface. The difference between my plan and yours is that I put EPDM rubber roofing on the roof. The rim joist will be relieved between the joists for drainage. I figure the EPDM will last at least 50 years, by which time I will either be 110 years old or the next owner can replace it. The deck will be only nominally attached to the roof, so it could theoretically be moved if the roof needs work. I like the idea of making it in sections that would be more portable.
