Re: Forrest WWII vs ????
Dave Paine
>On the topic of saw blades, there is no single solution for every cut in every material on every saw.
I have a Forrest WWII 40 tooth regular kerf and 30 tooth thin kerf. These blades produce the smoothest finished cuts. They are both ABT so if I need to cut a dado, they do not leave a flat surface.
If I am cutting thick dense stock such as 8/4 maple, I can get burning of the cut line, since I "only" have 1 3/4 HP motor, which limits my cutting rate.
I also have a Ridge carbide blade. This is 40 tooth regular kerf and does not burn as much. Likely due to better side clearance of the blade steel compared to Forrest. So I get less burning. It cuts well, and I feel a ready to finish cut, but to be honest, not as smooth as the Forrest. This is also ABT blade.
Forrest and Ridge blades cost about the same.
I also have a Freud blade forget the model number. This is thin kerf and 24 tooth. It was less than 1/2 the cost of the Forrest or Ridge. This is a flat tooth blade, so good for making dado's. It generates more noise when cutting, doe not make a cut as good as the Ridge, but the cut is flat.
So for dado's I use the Freud. FOr thick stock, I use the Ridge. If I want my best finish, I use the Forrest.
You pay's your money and makes your own choice.
I expect there are other good, perhaps better blades, just providing my experience on the few blades I own.
