analysis of situation and how I do it
Bill Tindall, E.TN
>Theory: In the situation described, namely rigid panel, glue, flexible strip, clamps spaced on other side of strip, what is the distribution of force on the joint? In the hypothetical case where the strip is perfectly rigid, one clamp will uniformly distribute its force along the joint, In the other hypothetical extreme, perfectly nonrigid, the clamp force will not extend beyond the clamp edge. I believe, awaiting a mechanical engineer to properly calculate the situation using the stiffness of wood, that the force extends well beyond the 45 degree estimation commonly proposed.
In addition, optimum clamping pressure for yellow glue and panel joints is more than 100 psi, while for veneer 15 psi is adequate. I believe the edge band situation is closer to veneer than panel joints, so huge pressures are unnecessary for success in holding an edge band on. In any case I have not had one fall off. I think more than 100 psi at the clamp gets me at least 15 psi well distanced from the clamp edge.
What I do:
1. prepare panel edge to be straight, or as least don't have any abrupt gaps that would require the edge band to sharply bend to conform to the panel edge. The edge band must be smooth, but it is unimportant that it be straight.
2. Apply a bead of glue to the edge band. Rub edge band against panel edge to distribute glue on both surfaces.
3. Assemble joint- panel, glue, edge band and a caul. The whole assembly sits on the loosened clamps. I prefer a somewhat flexible caul so it can conform to any gentle curvature of the caul or panel. For this application I would use a 3/4-1" caul I keep on hand for these jobs.
4. Begin tightening clamps starting at one end. Align edge band as you go along tightening clamps. A clamp every 6" will do for the task at hand.
5. Look for squeeze out. Too much squeeze out will obscure this observation. A good squeeze out results from adequate clamp pressure. The 6" spacing enables an additional clamp to be installed if there seems to be a gap somewhere as evidenced by the squeeze out, or lack there of. .
For edge banding I apply the over sized band and let the edges hang over. They are trimmed flush later with a hand plane. I have been doing just this task on 1/4" x 1" cock beading on a project. In this case the bead needs to be precisely aligned. I have techniques for aligning.
