Washing DC filter bags?
Charles R. Smith
>I have a question about cleaning the filter bag on a dust collector...
I have a Steel City 1 HP collector (model 65110) that is sucking a lot less now than when it was new a couple of months ago. The decreased air flow is apparent even at the opening to the DC machine.
The manual doesn't help, as it was obviously written by lawyers and not woodworkers. All it says is that if the motor is hot, to "empty and clean the bag".
Is it OK to stick it in the washing machine?
Re: Washing DC filter bags?
waroland
>I don't think I would do that. Usually all you need to do is whack it a few times to loosen the dust and let it fall into the collection bag. You did not mention what micron you bag filters down to. The smaller the micron filter capibility the more air flow you will have.
Chuck in ND
>Some manufacturers say not to wash their DC bags without giveing a detailed reason. So I just went ahead and assumed that maybe they would shrink and the fibers would get too tight if put in a washing machine, or they want to sell more bags. So instead of doing that, I just hung mine upside down on the clothesline and sprayed them out with the garden hose. It seemed to work ok on the Grizzly bags. Try it at your own risk.
Re: What ?
Chuck in ND
>The smaller the micron filter capibility the more air flow you will have? Common sense tells me something is wrong with that statement.
DON'T
>The filter cake and dust help the filtration. If you have a "shaker felt" bag, it starts off filtering at 3-5 microns particle size. After the dust builds up in the bag weave, it will filter at less than 1 micron particle size.
Just give it a good whack and dump it. Don't wash it.
Uncommon sense
Neal in San Jose
>If you compare a piece of peg board with a piece of window screen, you will see that the peg board will allow passage of things up to !/4 inch in diameter, but not very much air because most of the board is, well, board. The screen will resist passage of very small things, like gnats, but pass a lot of air because it is mostly holes.
The cloth filter bags are kinda like that, altho a lot more complicated with surface coatings, "toasting the insides" etc. The threads in a cheap stock bag are very large, like the board in the peg board with few large holes, while the threads in the more efficient bags are much smaller, like the screen, with many, many smaller holes which actually allows more air passage.
Re: Explanation, I hope  *LINK*
Chuck in ND
DC bags
Re: Uncommon sense
Bill Earl
>When I replaced my old 30 micron woven bags with 1 micron needle felt bags, the air-flow improved dramatically. At first I thought I had a serious leak, because the bags didn't inflate fully, they just gently puffed up a little when I turned it on. But the real reason was that the improved permeability of the felt reduced the back-pressure significantly.
Ed Mulligan, Cape Cod
>Woodcraft on their site claims the bag is a washable 1 micron bag so (a.) yes it can be washed and (b.) I'd look elsewhere for the problem. I had 1 micron bags on a 1 hp dc for years with no problems and no washing.
Look for a leak or leaks in your ductwork. It doesn't take much leakage to severely affect your dc performance.
One way to find leaks is to let smoke rise around a fitting. You'll be able to see it if the smoke is drawn into the ductwork. I used a length of smoldering cotton rope as a smoke generator.
Re: The manual
Chuck in ND
>The manual also says to look for clogs in the hose and blower houseing. I have experienced that after cutting moist treated lumber that the dust can stick to the impeller blades. Is the motor geting hoter then normal ?
>I have whatever cheap bag came on my Delta 1 1/2hp DC. I have not washed it, but I did take it off and turn it inside out and shake it, outdoors. This was after shaking it into the bag on the DC. The amount of dust that came off the bag was stunning. Definitely something to do away from or downwind of your car and away from your neighbors. I don't think it ever stopped emitting dust. I just got tired and put it back on the machine. The improvement in the air flow was amazing. This reminds me, time to do it again. My bag is out side the shop in an exterior closet, so I don't care what micron it is.
Ps...I would not wash it......
>Seems like it would permanently shrink the fibers, trap some of the dust, clog the holes, turn the crap into mud, and be hard on the washer and dryer.
Re: Ps...I would not wash it......
dan arrowsmith
>I used to run an industrial dust collector with around 200 bags in it. we would send the bags out to be laundered a couple of times but after that they had shrank to much to fit.
del schisler
>i have the same DC Delta 1 1/2hp DC What i do is take the bag off I have a 30" exhaust fan and i have a bench in frount of the fan I turn the bag inside out and use my air hose and blow the dust off the bag It take's some time but i do this tell their is just a litte left Like not much come's off I wouldn't wash the bag Just air hose blowing off Make's it work like new When i put it back on It will not inflate full like it was before It take's a bag full of shaveing's and it inflates full I clean the bag after 4 time's full I find this to work's for me I plain walnut oak mahogany cherry and maybe some maple I have the vac hook up to the delta 14" with riser planer and jointer Also use it to pick up the wood dust I blow all the dust to the west end where the 30" fan is and than blow to the corner Than use the hose to suck up the dust I dont use a broom Try this it work's well For over 15yrs in this shop I do this after each session in the shop I like it clean I also blow all the tool's off also Just like them to be like new when i use them again Than it's beer time
