We value your privacy.
>Once you figure out the release/tightening mechanisms on this machine, changing the sandpaper is pretty straight forward. However, can you really get the paper snug on the drum, or do you live with the little bit of sloppiness? This looseness tends to work over to the right side and eventually tears the belt. Am I missing something? TIA Nick
>I have a Performax 16/32. I assume the tension?release mechanism is similar. It does take a bit of practice to get the belt tight, but it can be done. I clip the belt in the open/outer end and carefully wind the belt. What I find helps is to insert the tip of the belt into the clip and note where it passes over the drum. Take it out and put a crease in the belt at that point. Gives a good sharp point for the belt to "start". Do the same on the other end. Snugly wind the belt, put a crease in it, make the crease about an 1/8" "short" and install the tip in the clip and try to do that little magic trick that requires thirteen fingers and three thumbs. Somehow, release the part of the clip that grabs the sandpaper before releasing the part of the clip that puts tension on the belt. I find winding the belt with about a 1/16" space between the wraps works well. Never let them over lap or you will get burns and ruin the belt. Having the belt tight really improves the sanding. It will sand flat and with crisp square edges. if you let the belt be loose, it will be "soft" and sort of round over the edges.
I had two or three belts that the end had torn off. Some of them were nearly new. Really hated tossing them or using them for something else. I hit on the idea of putting the good end in the starter clip and carefully winding the belt and using a piece of double stick tape to hold the torn end. Then I just sanded with all but the inner inch or two of the drum. Worked great. Now that I think of it, this might work well for getting that last little bit of slack out of the belt.
