We value your privacy.
>Have any of you attempted to install an above-ground pool yourself?
Is this something the typical "do-it-yourself" person could tackle?
Pitfalls or potential problems?
The site is already fairly level, but how difficult is it to achieve a level surface (I don't have, nor know how to use surveyors transits and such....).
I know I can round up 3 or 4 other helpers, so manpower isn't the problem - just wondering if this is something better left to the "pro's". If sao, does anyone know roughly what it costs to install, say a 27 foot round pool in Maryland???
>I got called to go down and "help" BIL set one up. Against my better judgement I did. I had to talk myself blue to get them to buy a small load of sand to put under it. They dumped it in the driveway and when I went down the next weekend the sand was still in the driveway and the pool was shredded beyond any repair. Yes kids, they filled it up anyway. Did'nt level, sand or even clear out debris and bumps. Since I've never seen one beyond square one I'd say preping the area is pitfall #1.
>I installed a 28 by 14 footer almost entirely by myself. The 2 biggest things to get right are the leveling (use several inches of sand under it to ensure you have a surface that wont punture the bottom of the pool) and getting the pier supports in the right spots.
You don't need a transit. Just use a 4 foot level on top of a nice straight 2 x 4 as your leveling tool. Work on the leveling as long as it takes as this is very important. Don't skimp on the sand or you will regret it later when a rock works its way up and punctures the bottom.
>I have installed above ground pools but it has been many years ago. Installing it on a good bed of level sand is the first important thing to do. As others have said you don't need a transit. A level and a long 2x4 will work fine. Don't skimp on the sand.
>My son and I put up a 28' a few years ago. I used a tiller to soften the grund so we could level it. Actualy, I installed a center bottom drain, so I pitched it to the center, but the sides were dead on level. Put down heavy black plastic on the dirt, then covered with 4" - 6" of fine sand. Wet the sand and leveled the heck out of it. Had about 10 people help put the liner up on the frame.
Was a wonderful pool for years. We sold the house and moved before I saw it get old and ugly. Good luck on your project.
>Have installed 3 16x32 ovals and as others have said preparation is the key. Do NOT build up the low end with sand to level the site. Dig down the high end. use a base of about 4" sand and I have had great luck with a "Happy feet pad" it is just 3/8" or so foam pad under the liner.Make sure there are NO STONES!!! Any stone will work it's way up to the liner. A trick to installing a wrinkle free liner is to fill some temporary pools with water and then pump them all into the big pool along with as many hoses as you can all at once. The idea is to get as much water in as quickly as possible. You can do it, enlist a group of helpers and it will go fine.
>The only items I can add over what has been said is we sterilized the soil so nothing would grow under the pool.
Find the low spot and dig everything down to that before adding a bed of sand.
We used a water level (just clear tubing) but a garden hose can be used, just takes more time.
In rural area on a well we bought municipal water and had it hauled in a farm water wagon.
It did take a lot of friends and temporay braces to stablize the sides till the water level could stabilize the pool. Still ended up with some small folds/wrinkles in the bottom.
Being rural they did not fence in the pool in our small group of rural homes and probably not very wise/legal.
After helping with this they very seldom used the pool!
Another friend had an in ground pool and either way it was a pain to prep either for winter in Iowa. No heaters so it decreased the usage time or froze your ---- to swim early.
