OT Refrigerator Ice Maker
Tom Rex
>My ice maker does not complete the cycle.
The cubes are made and almost ready to drop.
The wire thing that you can shut the ice maker off with bumps up & down but the cubes do not move.
What repair does this thing need?
How difficult is it?
Would I be better to get a new unit?
Are the replacement units universal (HA, I know the answer to this one)?
Thanks,
Tom
Re: OT Refrigerator Ice Maker
Joseph Mulherin, Sr
>Tom, a website that might help you: www.repairclinic.com
sort of a solution
Bill Tindall, E.TN
>We have an appliance repair shop near by. When I have a problem like this I go to them and the nice lady provides what is needed. For the ice maker it was simply a board. She told me to go home and stick my nose in the unit and smell for burnt electrical components. Sure enough the smell was there indicating the fix was a new board. Other times I needed to replace the whole unit.
With luck you will have a similarly helpful place near by.
BTW I have fixed more ice makers than even cars. Apparently they are frail. Also, be sure the water supply to it is armored. I have had two friends flood the house when the common plastic tubing ruptured. With age the white plastic tubing (polyethyelene) gets brittle.
Re: Old Fart's alternative
Kneale Brownson..Awaiting return to CO snows
>Shut off the water supply and get some ice cube trays.
I wouldn't have water to a fridge or ice from it. Water stagnates too much unless you've got a big family making use of it multiple times every day.
We use filtered tap water in trays to make ice and store a daily fresh supply in the fridge during the summer.
>I have replaced several. They are not universal. Go to the Brand website to find out how to get a replacement. It'll be $150, or so.
How do you know when fresh water in ice form is "stagnant?" LOL
Clint
Re: stagnant water, not ice
>It's the water in the tube at the back of the fridge, where all the heat goes when it's sucked out of the box, that gets stagnant unless it flows frequently.
GalenV in Iowa
>I belong to that club!
Bad taste from the water that sits in the tube forever if the ice bucket is full and not used. I hate the refrig taste to the hard marble shaped ice cubes that have shrunk for the frostless freezer cylces and absorbed every odor in the fridge.
Even ice cube trays I dump if getting something out of the freezer and see thay have not been used in a while.
Besides that I don't drink water anyway if I can keep from it. Water taste bad in general. And to think I designed water treatment equipment for 39 years. Guess when you go to a municipal water plant and see minnows swimming around in the filters it kinda turns you off of water! Or the foot of slime in the bottom of a finished water resevoir.
What else can I say to turn your stomach on drinking water?
Galen
Siemens Water Technologies- retired, thank you very much!
Re: Ice maker and a most useful web site *LINK*
Bob Entwisle in NJ
>The automatic ice maker process that I am familiar with is:
1- open water valve for a fixed time (7 to 10 second) to fill ice tray.
2- Wait a while to freeze water into ice, determined by a thermostat.
3- Turn on small heater to free ice from the mold
4- Turn on motor to �sweep� the cubes from the mold and into the bin.
It sounds like your problem is at stage 3 or 4 if the heater doesn�t run to free the cubes then the motor can�t move them out of the mold.
The web link http://fixitnow.com/ has been extremely useful to me over the past couple years for several appliance repairs.
To keep from having �old stagnant� ice cubes it�s a simple matter to empty the ice cube container thus keeping the water moving in the tube etc.
