Have a question? Ask Woody!
Kitchen cabinet top coats
Mitch from Canada
>Hey all,
I've built a large cabinet to enclose a refrigerator for my sister and am now making wine racks to go beside two cabinets.
I've been working at finding a similar top coat to what the existing cabinets have for the cabinets I just built. I'm not doing too bad matching the color, but trying to find out what finish is on the current cabinets is proving difficult. It doesn't scratch very easy, but it's very thin. It's almost like there isn't any top coat. It has almost no sheen.
I had read that some manufactured cabinets use baked on laquer. I don't have spray laquer equipment but I have seen Laquer in cans for brush spreading...it says it drys over a 2 hour span. Anyone have experience with this stuff?
I don't think it's a varnish either.
Had thought of using Danish Oil as the top coat...but some say it isn't very durable.
I like the building part, but this "matching someone elses finish" is just wild.
Any help is very appreciated.
Mitch
Re: Kitchen cabinet top coats
Ed Mulligan, Cape Cod
>Regarding baked on lacquer, you may be referring to lacquer cured with ultra-violet light. It's used in the guitar-making industry. I don't know if it's used for kitchen cabinets but it's possible. Conversion varnish is commonly used for cabinet coating.
Your closest match will come from spraying a matte lacquer. Since you don't have spray equipment, you might experiment with rattle cans from the local paint store. I would build the film with gloss coats and then apply a coat or two of matte but you had best test before committing to the real piece.
Another work-around: make your finish entirely different from the other cabinets. In other words don't match. Make it a solid color or a different stain.
David Yoho
>Mitch, the main thing you have to answer, since the original topcoat is not known, is does it matter if you match it or not? Since you have no spray equipment that limits your application choices to spray cans, brushing, and wiping.
Personally, I don't like the results I get from spray cans and brushing wouldn't be my first choice for surfaces where brush marks might be seen (no matter how hard I try, there always seems to be at least some). Therefore, I would lean toward wiping.
If you decide matching the type of topcoat on the existing cabinets isn't necessary but want to maintain the look, you might think about wiping on either a good water-based topcoat or an oil based one like Waterlox. Wiping doesn't build fast so it will take more applications to get where brushing or spraying does.
The water-based will provide a clear coat while the oil-based will add an amber tint. If you plan to use the oil from the beginning, it's easy to adjust the stain color to allow for the amber color it imparts and end up where you want it in the end. If that's not the case, perhaps a water-based would fill the bill. For a small investment, you could pick up the basic Earlex sprayer, which would easily be up to the project you're doing.
At any rate, I'd recommend applying the high gloss version of oil-based all the way to the final coat. Then make the final one or two coats in the satin or matte version of the same finish.
David
Mitch from Canada
>Thanks for the advice. I'll let you know what I go with and I'll try to post pics when it's done.
Mitch
