Re: Wireless network setup OT
Bill Howatt
>Normally, wireless connections are setup between a PC and router. The router normally comes with software that makes the setup "easy". The term "easy" only means "it could be worse if you tried it from scratch".
If you look at the documentation for the router it will, among other things, describe what type of encryption is available for the wireless connections. WEP and WPA or WPA2 are the common ones and the latter is the current preferred one, as far as I know.
What you must do is setup both the router and the PC's wireless card to use the same method and the same password needs to be entered into the security setup screen for both the PC and the router. It is possible not to have every security option available at the PC's wireless card and the router. If that happens then you must select one that is available on both.
If you are going to pursue this yourself, first try and setup the router/PC connection with the default connection with no security. After you get that running then you can setup the security.
Bill
