refinish
refinish
refinish
mike mcnerney
>I am refinishing a 15 year old cherry vanity countertop, originally done with rockhard table top varnish. I want to use a waterbase floor finish. As far as stripping goes how perfect do I need to get it.
MM in ottawa
Re: refinish
Re: refinish
>I recently used that orange flavored stripper on a dresser that had multiple coats of old varnish. It took two doses, but did a good job. It's easy and effective. After that a rubdown with thinner and maroon scotchbrite should be sufficient prep for the waterborne.
Clint
Re: refinish
Re: refinish
Fred Davis
>apply a liberal coat of your stripper and then cover it with a plastic sheet like Saran Wrap.
This slows down the evaporation of the stripper and lets it go deeper then it would without the Saran wrap.
This technique combined with a aggressive stripper, not one advertised as "user friendly"for instance , generally does the job in in one application.
Wipe it down with Mineral Spirits(paint thinner) and if it neds smoothing, do like you did when you built it.
For myself , any sanding would be with 220 Garnet , but that's just me.
FredD
FredD
Re: refinish
Re: refinish
steve mackay
>Did a "buffet" last summer with the orange stuff. Five coats of paint (from black to purple to red ! Go figure !)of different flavors. Came out very well.
