Shop Vac Hose
Tom Rex in TX
>Has anyone come up with a good way to store the hos on a shop vac?
That thing is so hard to keep from flopping around the floor.
Shop Vac Hose
Tom Rex in TX
Re: Shop Vac Hose
>Good Morning Tom,
I have two shop vacs, one Sears and one Ridgid. Both have uncontrollable hoses. Kept in the same room, they remind me of a couple physically passionate snakes. My wife tells me to put them in separate rooms and keep the doors closed. :<)
George
Hos or hose? :-)
Steve antonucci
>I don't. I curl it up and hang it. Take it off the wall when I need it.
Steve
Shop Vac Hose - My Way
Bricofleur
>Tom,
I solved this issue by drilling a 1/4" hole at the business end of the hose, near the edge, being sure that all accessories would cover up the hole while in use to prevent any air leaks. I drove a nail in the side of a ceiling joist, in line with the vac, to hang it. The other end is always hooked to the vac itself, ready for hard sucking work. My three vacs are treated the same way.
Does the vac looks like a resting elephant ?
PS: If you take a closer look on the rigth upper side of the vac you will see the muffler. This is a must !
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Re: Shop Vac Hose
Ralph Lipeles
>I use a big hook with a loop at one end and screw threads on the other. I screw it into a cieling joist. It is the kind of hook that you get at a hardware store, packages of 2, usually used for hanging bicycles and similar stuff.
Ralph Lipeles
Same,only bench level . . .
steve mackay
>I've got this "auxillary" bar. The hose end kinda wedges in for a perfect, handy fit within arm's reach.
Re: Shop Vac Hose
>My Ridgid has a plastic clip shaped like back-to-back "C"s. One C clips onto the hose near the vacuum, then you wrap the rest of the hose around the motor housing and clip the end onto the other half of the C. Primitive but adequate for my needs. (If I had open joists, I might try that hang-up method.
Cheers.
E
Bricofleur
>Ellis,
Having an open joist is easy: A ladder and a hammer!!!
How about using a cup hook screwed to the ceiling?
Best,
Serge
Re: Muffler- Ain't got no stinking muffler!
GalenV in Iowa
>A muffler would be nice but my cheap Sears Crapsman exhausts the air around to rim by the handles!!!! Would like to meet the designer! Pull the unit near your dust pile and it will be blown away before you can suck it up!
I amaze myself that I put up with it, but it was a gift.
Replaced a twenty year old true SHOP VAC that could pick up 3/4" bolts or could lift water out of the hot tub 30" inches high. Metal can finally rusted out.
They don't build em like they use to!
Galen
Yeah, I guess I could have figured that out :-)
