Outdoor Project Question...
Rob Hix - King George, VA
>Hey all,
For some number of years I have wanted a grilling table on the deck. Up until recently I thought I wanted the top made out of wood. Now I am not so certain. I am thinking wood could get really nasty from stuff dripping off of the spatulas, etc. It will be totally exposed to the elements on a south-facing deck.
I know I could always have something like a granite tile to lay the spatula on, but that would be something else to keep up with.
My second thought was to use formica, but I am unsure how it and the contact cement would hold up in the elements.
Then I thought of sheet metal, but I would have the same weather problem with the glue.
One option would also be a solid granite top, but I want something that I can afford to make.
The final option I can come up with is a granite tile top, but what would I do about the grout?
So, the question it, what would you use, and how would you go about doing it? Any experience here would be a great help
Thanks in advance,
Rob Hix
Re: Outdoor Project Question...
>Use 12" granite or porcelain tile keeping the grout lines to 1/16" and use an epoxy grout or a non-sanded grout with a sealer.
Clint
>Make the substrate out of 5/4" pressure treated decking.
Clint
Kneale Brownson..Awaiting return to CO snows
>I'd use a solid-surface plastic product. You can use your woodworking machinery on it, but it's both durable and waterproof. The glues are more like chemical welds. I've got a showerstall with walls made from it that's just like new after almost 20 years of use.
Re: Outdoor Project Question... x's 2
Carol - headed home
>A timely question.
I want to install a gas grill permanently out on my back deck. I need a prep/serving table that I'd also like to be a permanent fixture.
My deck has a southeastern exposure to Arizona sun at 6200 feet.
Summer outdoor temps occasionally reach 100�.
Occasional winter snows and temps into the 'teens.
What is the 'plastic product' you refer to?
I might entertain the idea of a covered area for this - if I have to.
Ed Mulligan, Cape Cod
>Interesting problem. I don't have any experience to share but I'll throw out a few ideas. How about thick glass, like is used in coffee table tops, for a surface? Another idea, loose bricks set in sand, no grout. If you do use sheet metal, epoxy is a weatherproof adhesive. I wonder if a sheet of aluminum flashing glued down with epoxy to a piece of plywood would work. Copper would look real nice. A small piece shouldn't cost too much. Stainless steel? If the metal is thick enough, you probably would not have to glue the entire surface - a few dabs of silicone or construction adhesive would suffice.
John E in SC
>I've had an outdoor table I made about 10 years ago that has held up well. I used cheap ceramic tile on a Durock backer, with table made of PT lumber. Grout lines are about 1/4", and it's held up fine with no maintenance. Granite tile with small grout lines would look great, and probably do even better.
Another think you might consider is a table out of the plastic lumber like Trex decking. Use stainless steel fasteners, and I can't imagine you'ld have any issues with weather. Just be careful and don't sit anything too hot on it. Tile would have an advantage if you're using it to sit hot pots, etc.
John
Corian?
Tony - Memphis
Re: Ceramic tile with dark grout
Brian in Brighton
>Seal the grout every year and it should be quite nice.
Brian in Brighton
BrianA
>Concrete. I have made Kitchen and bath counter tops out of concrete. Easy project and look quite nice when done. Lots of ability to personalize them.
You could lay all kinds of neat things on the bottom of the mold (which would show on the top)which would make a real cool BBQ table
Brian
stuff like this *LINK*
>I don't know this company or its product specifically, but they have the kinds of solid surface stuff I was thinking of.
One Producer
Re: Outdoor Project Question...------WebKitFormBou
Eric in Silicon Valley------WebKitFormBoundaryNeuJ
>I agree with Kneale. Depending on the size you are looking for, you might be able to get a Corian sink or stovetop cutout for free by a kitchen and bathroom contractor, or a larger piece from someone replacing their Corian or similar material countertop.
Like he said, you can use a router, tablesaw, jigsaw, etc with it.
I've got a Corian kitchen countertop getting replaced next month, but, I'm a few thousand miles away. Otherwise, I'd be happy to give it to someone who could use it.
------WebKitFormBoundaryLh+bLq4iJjOQtTS2
