Re: DP Mobile Base
AZ, Colorado Springs
>Bear with me as I tell a story. There is a suggestion in here:
I have full size pick up truck. Also used to have a golden retriever. When the dog got old and had trouble jumping into the back of the truck, I took a sheet of plywood, cut it down to fit in between the wheel humps (and between the front of the bed and tailgate), and covered it with astro turf. Also bolted a handle to one end (near the tailgate of the truck). I could pull the board way out and lay the end on the pavement and it made a ramp for the dog (on about a 45 or 50 degree angle). When the dog was inside, I'd slowly push the plywood into the truck, and the dog eventually would hop onand I could get it all the way into the truck, and it fits snugly. It also provides a flat, carpeted bottom to the truck. (More comfortable for the kids and dogs who rode back there). And, I can pull it out partway to load or unload a bunch of small items.
When I got my drill press, my son and I went to pick it up. How to load the drill press? We pull the plywood out of truck as described above then laid the drill press over against it. We then picked up the end of the plywood and slid it, with the drill press, into the back of the truck. Voila!
So, the suggestion: if you have a pick up truck (or access to one), do something similar. Instead of completely loading the drill press, leave sticking a little over the tailgate and mount the base. You could do something similar with a large work bench, but the pickup bed and tailgate are a bit lower (at least lower than my work bench) and I think easier to put the drill press onto and off of safely. Once the wheels are installed you'll definitely need a helper to assist in steadying the drill press when you put it back upright.
Good luck.
