OT - composite decking
Bill in IN
>I'm looking at composite decking for a new deck. Anyone have any experience with this stuff over time?
Bill in IN
Re: OT - composite decking
Bill Howatt
>Trex for about 5 years. Looks about the same as when it was installed. It was a bit darker brown when installed than the top is now. Sun in summer, ice and snow in winter.
Bill
3 years with Veranda
Lee Schierer - McKean, PA
>We recovered our front deck with Veranda composite decking from the Orange Borg. It looks fine after 3 summers and winters. I did note that it is less slippery with a freeze or frost than the treated lumber decking was. The composite doesn't absorb water. It also holds up well to snow shoveling, I had more than 140" of white stuff this winter. We get a bit of algae growing on it since part of it is shaded most of the day, but soap and water with a bit of bleach once a year seems to clean it off.
Lee
Re: 3 years with Veranda
Bill Howatt
>I'll say the same for Trex both for being less slippery and the mold. I find it strange that people say they've heard it's slippery compared to wood but I find the opposite to be true. As for the mold, I have an old sprayer that I make up some bleach water, spray it on, wait a couple of minutes or so, and then just hose it off.
Bill
Chuck in ND
>I put up a deck for a friend a few years ago and used Trex with powder coated aluminum spindles, he's been thrilled with it since day one. With some of the leftover scraps I built him 3 planter boxes that are also shown in this picture.
too hot for bare feet after a few hours of sun?
Ron Griffin
John McGaw
>I have been using whatever cheap brand it is that Lowe's sells. It is held down by Ebty invisible fasteners to a treated lumber frame. It looks and acts pretty much exactly as it has for the past five years. Only complaint is that, in my situation, the Ebty fasteners space the boards a bit too close and the gaps get plugged by the tons of organic junk that falls from the trees every year. Sometimes cleaning the gaps using the pressure washer is a big problem and an invitation to an unwanted shower. The surface of the boards are easily cleaned with the pressure washer.
R. Gryder
>Decks I installed seven years ago still looks great. R.
>Don't know the brand, but a friend installed some that is gray about two years ago. Used stainless steel screws. Must have been the wrong ones. They all look like mushrooms. Check on using the right screws. Huge difference in the appearance.
Chuck Kettler Greenwood IN
>I have done two decks with Trex and SS screws. First deck looks great after 14 years. I predrill for the screws to avoid the mushroom problem. I still use scraps from the first deck to hold down nets over my raspberries and after all the years of ground contact the scraps are in good shape.
Bill Howatt
>I used SS trim head screws which have a much smaller head than regular decks screws and then hammered the churned up plastic down as recommended by Trex. The only time I easily see little bumps on top of the screws is when the deck is wet.
My other deck allowed me to use under-deck fastening.
Bill
Re: OT - composite decking *LINK*
DizD
>I saw this new product at a local dealer last week. I was aware of the technology from work I had been involved in before I retired, but just found out it is now available commercially. Its an impressive looking product, both appearance wise and technology wise - wood preserved and stabilized without chemical treatment.
No personal knowledge of how it performs, but thought you might be interested in knowing about an alternative. The dealer says it is slightly less costly than composites from the blue box.
http://www.radiancewood.com
