We value your privacy.
>Okay, my geek pals, I have a problem. I just got a 3TB external RAID hard drive to house images, video, music, etc. and now I find that Windows XP won't even recognize the drive if it is over 2TB. Further, it won't let me partition the drive. The tech support guy told me that I could format it on a Vista machine, but I don't have one of those.
Any help, or will I actually need to find a Vista machine to make this thing work?
>I think the issue is with the MBR method of setting up the disks and this does cause a 2TB limit. The other method used by Vista, Windows Server, XP-64bit, is the GPT.
Here is a link below.
I think you need to find a Vista machine alright or perhaps a 64-bit XP one.
You need a utility to partition the drive. I use Partition COmmander 10 but there are many others. Once you partition it, Windows XP will recognize all of it.
>Is it a network drive (connects to your PC with an ethernet cable) or a USB drive? What model is it?
One thing to consider is how you intend to use this external drive. Although you say it's a 3 TB drive, it's most likely not one big 3 TB hard drive. I don't think those exist, yet. It may actually hold two 1.5 TB drives within it, or even four 750 GB drives, to give you a total of 3 TB of storage, theoretically.
If so, it should have software to help determine how to set up those drives within the drive. The usual way of setting up this sort of external drive is to use RAID 0 so that the individual drives look like one gigantic hard drive, which would give you 3 TB of storage. The down side with this setup is that if either drive goes, you may lose all your data, even though one drive may still be good. And since you are using two drives, you are theoretically doubling your chances for a hard drive failure.
Another way to set up these external drives is to use RAID 1, which means that the two drives act as mirrors of each other. This cuts down your storage to 1.5 TB, but the good news is that you are automatically making a backup as you use your external drive, and if one of the two drives goes out, you don't lose any data. Of course, you would replace the failed internal drive ASAP, and after replacing it, it mirrors the good drive, and you're back in business.
Either way, the drive should come with software to help set it up. Windows XP does have a 2 TB max, so I don't think you'll be able to set it up as a big 3 TB drive. What I would strongly suggest is to set it up as a 1.5 TB RAID 1 system, so you have an automatic back up, and get a second external drive if you really need 3 TB of storage right now.
(I just realized that I probably am telling you stuff you already know. Sorry if I did that.)
>Try PartedMagic from PartedMagic.com , if you don't mind diving into the weird world of Linux. You download the .ISO file and burn it to a CD using the "burn image" option of your CD burning software (Not the XP CD burner). I don't have a drive bigger than 500gb so I don't know if PartedMagic has any disk size limitations or not. After you create the PartedMagic disk, stuff it back in the CD drive and reboot. After a time and a bunch of goobledegook messages it should start up and you should have the capability to partition your drive to any number of partitions you like and to format to NTFS, FAT32, or anything else that suits your fancy. Be really really really careful about selecting the drive to partition: PartitionMagic will re-partition any drive on your computer with minimal warning about what it is up to.
>A local technician tried a couple of those partitioning utilities to no avail. One might have been Partition Magic(?). Maybe the one you suggest would do the trick.The problem we ran into is that XP doesn't know how to interpret something that big so it pretends it doesn't exist. If you can't get the disk to show up in your disk manager, you can't partition it; at least that's what I'm getting from this exercise so far.
I'm leaning towards trading this puppy in for a couple smaller drives. As Wilbur pointed out, if the drive goes bad, you lose everything. Having one huge drive just magnifies the damage.
It is a G-Tech G-RAID3, with USB, FW and eSATA connections.
It's for data and it has two drives in a RAID0 configuration. I already have storage units and network drives that contain several terabytes of data, but I wanted to consolidate my photo and music backups. This would free up a couple other external hard drives to use for backups and miscellaneous storage.
There's the rub, Wilbur. The "installation" disk is just a bunch of marketing PDFs, although they do mention drivers, but they don't exist, not that it matters because you never get past the initial partitioning. All their documentation and packaging and marketing says that 32-bit Windows XP is a suitable OS, but it is not, at least not without huge hassles. Even the tech guys tell you that. One of them told me to use a Vista machine to partition the drive. What if you don't have one?
This one is RAID 0. I don't see any options to switch it to something else.
I like the RAID 1 idea, Wilbur, but I need the 3TB. I think at this point I'm going to send it back to the place I bought it and exchange it for two smaller drives that will work right out of the box.
I'm a mile wide and an inch deep on this stuff, Wilbur. I appreciate your good advice.
I saw this in a little footnote on the G-Tech website:
"*The G-RAID3 3TB model is not supported by Windows XP or older 32-bit operating systems which limit maximum volume size to 2TB. G-RAID3 3TB is compatible with systems running Mac OS X, Windows Vista or other 64-bit operating systems."
So it looks like you'll have to return it.
Or this could be the perfect excuse to get a Mac. :@)
>One other free option--I don't know if it'll work or not but all it'll cost you is time. There's a program called BootItNG from terabyteunlimited.com. It's shareware--free to use for 30 days. I bought it and use it as a boot and partition manager. It doesn't use Windows at all so Windows 2TB limitation shouldn't enter into it. It'll create FAT, FAT32, NTFS, different Linux file systems and some I"ve never heard of. It might be wise to disconnect any existing drives before booting BootItNG. That will guarantee you won't mess with existing installations. That's also the advantage of a disk management utility that doesn't use Windows--if a Windows drive isn't connected, you can't screw it up. Advice worth what you paid for it;-)
>Personally, I would run Linux before I would get a (aaarrrggghhh) Macintosh. Wait - I do run Linux! Well, about 5% of the time anyway. Actually, I play with Linux.
>If you are considering an upgrade to Vista, hold off until fall. MS is suposed to be releasing Windows 7 which from the reviews I've seen is far superior to Vista, and has an XP emulator built in for those "legacy" programs that we all seem to have around.
>I have been running the Windows 7 beta and release candidate and am fairly well impressed (Note: I have never used Vista!). Networking is easy and access to a printer on another computer on the network was almost automatic. Avast antivirus, Nero 8, Lightscribe, Xnview all work just fine. My crusty old Office 97 seems to work except for macros. It performs adequately on an old 2000ghz Athlon with 1gb RAM, not quite as well as XP but just as well as Linux Ubuntu 9.04. The user interface is drastically different from XP and is something of a cultural shock. I too would wait for Win 7 rather than buying a machine with Vista.
>My suggestion was to use a Linux based partition utility, not one that will run under XP. To use one of these, you would be booting the computer with a Linux operating system. However, I still don't know if the Linux based utilities have a hard drive size limitation or not.
>I just did a quick search and it looks like the Linux based partitioners might also have a 2tb limit unless you have a wild eyed Linux guru doing the job. So you might as well forget everything I said!! If you hadn't already :)
>Actually, I run Linux on a computer that I use as a network file server. Gentoo Linux, to be exact.
If you are Linux savvy, one good way of making a file server is to take an old PC, and load it up with huge drives. Then you can configure it as RAID 0, 1, 5, or whatever.
>I basically only run linux on my two main computers. (my wife has a Vista laptop, but I almost never look at that one.) I have an install of xp in virtualbox that I keep around for tax software and such. I boot it up every couple of months for the updates then put it back to sleep.
