Second Thoughts on a DP Purchase...
Ken Bellock (Houston, TX)
>Took advantage of the 20% off Jet/Powermatic at Woodcraft last weekend, and bought a PM2800 on back order. I've been reading a lot of reviews since then, and it seems opinions are either extremely positive or negative. This seems to me like a poor QC issue, and I intend to inspect all castings when I go to pick it up, but I am still worried that I made the right choice. I will use it for woodworking only, so the minimum speed of 400 rpm doesn't bother me too much. I am more worried about getting a chinese lemon. As I put a lot of weight on the advice of the members of this message board, I would be much happier I think if a few members out there had some positive words about this drill press, and could use any advice on what to check first when picking it up and as I'm assembling it in my shop.
The manual also recommends not putting the DP on a mobile base, but with my small shop I am going to have to. Is this going to be a major problem?
Thanks in advance for all your advice.
Ken (Wishing Houston weather was like this year round)
Re: Second Thoughts on a DP Purchase...
>Well - I'd check the casting quality and the fit and finish. Do you have something you can check the run-out with? You can get something like the "Alineit" and clamp it to the table. If you have a nice piece of drill rod stock that is straight that would also help to check the alignment. Check the quill travel and see if it binds. There are a number of books on set-up and maintenance of shop tools. Woodcraft probably has them.
I don't have a mobile base on my drill press. I mounted thebase to a couple of 4 x 4s. I can "walk it" or drag it around my shop quite nicely (not that I ever do) - and I can vacuum under it.
Chuck in ND
>I know of a guy in South Dakota that came up here and bought a old Oliver lathe from me, before leaveing town he bought that model drill press and ended up takeing it back, he wasn't impressed with it at all. If I was looking for a large drill press I would seriously consider the Steel City 17". As far as puting a drill press on a mobile base, I've tried it on a 13" drill press and I can tell you that the problem is a drill press is very top heavy. If I was to ever do it again I WOULD NOT do it with a mobile base that lifts on one end, HTC makes some low profile mobile bases that don't lift. Also the mobile base would have to be large enough to go past the back of the motor, plus I would bolt the drill press to the mobile base and even maybe add some weight to the base of the press. Even after all that I feel it still wouldn't be safe. If you went to move it and for some reason one of the wheels catches something and locks up theres a high probability that it would tip. Just my opinion.
Tom MacGregor
>I have a monster 40's era Delta industrial 5 speed drill press in my tiny shop. It's on a custom made mobile base. I welded brackets for the locking swivel casters that keep the bottom of the DP base less than one inch off the floor - the casters are next to the base, not under it. I also used four inch diameter casters (purchased at salvage - so was the DP) that roll easier and are less likely to catch than smaller ones. It's still top-heavy and I need to be careful moving it, but the base is designed to minimize the risk. I also placed it against the wall where it doubles as an outfeed table for the radial arm saw (Shop Shot 759). I only need to move it forward a couple of feet once in a while to accomodate drilling large objects.
Nick Tuzzolino
>I have owned the 2800 for a little over a year. I love it. No problems. Truly a drill press made for woodworkers.
I think JL's suggestion of dragging it on 2x4s is a good one. A little wax would help. That is a mighty top heavy machine.
Have a strong helper available when you mount the motor onto the post.
Best wishes with your new toy!
Pete in Holland, MI
>Ditto on moving drill presses. Your new wheeled base otta have a larger spread than the current cast base. Even if you are careful, one hesitation at a wheel due to a sliver of wood or crack in the floor will cause enough of a hesitation on the base that the top will continue moving and head to the floor. Then it won't matter what kind of machine you bought.
Al Stokka - Cambridge, Iowa
>Ken,
Powermatic's caution re: mobile base is likely a liability advisory.
I have my drill press (16�" variable speed, and rack & pinion table height adjustment so it's extra top-heavy) on a mobile base just large enough to set the drill press into. While I have to be alert when moving the unit, I have no hesitation to do so. I am not a keep-it-spotless type of shop opertor (just ask Sweetie) so the sloping concrete floor is often littered with gravel, sand, (my garage doubles as a shop) and/or sawdust and wood chips. Never had an adrenilen dump when moving the drill press.
I say go for it!
Al
Dick Coers
>When Woodcraft first got one in our store, they plugged it in and ran it up and down the speed range. I thought it was very noisy for the price of the machine. The variable speed system was the source of the noise. It was smooth running, just loud in my opinion. You might want to run yours as well as look it over when it comes in. Good luck.
Kirk (KC) Constable
>I can move my drill press around easily enough without a mobile base or anything else underneath it. I built a wheeled platform for my PM719 mortiser and find it muuuuch more 'tippy'. Almost uncomfortably so, even with it bolted to the platform. It was rock steady on the floor. So I can see why they might caution against putting a DP on a base.
Larry Clinton At Frankfort (Central)., Indiana
>Ken, I purchased this press over a year ago and have used it for both wood and metal (90% wood). I am not overly impressed with the press, but it does do the job. Upon assembly the press had very little runout - I inserted a 1/2" dia. thompson hardened rod into the chuck and checked the runout about 4" below the chuck - it was less than .001 - very good. The table sliding extensions are very handy - but do require quite a bit of effort to extend/retract. The LED lighting works very well, and the laser alignment is easy to adjust and very accurate when properly aligned. I had a problem with the variable speed drive as received - found a bolt inside the system loose after a 1/2 hour inspection. After fixing that the drive works well, although a little "rough" feeling during adjustment and darn noisy for the price of the unit. I have had a few problems with the chuck, it fell out of the spindle (morse taper end came loose) the first time I used it for metal. I found a burr about 1/2 way up the taper adapter and removed it with a fine stone. The chuck has a tendency to tighten up when using a large bit - I have had to use a couple of channel locks to release it a few times. This week I disassembled the chuck and lubricated some areas, hope that fixes the "tightening" problem. (I did notice some wear on the jaws - more than I thought should be there for the use it has seen). The fit and finish are not what I expected from a $1000 piece of equipment. Although the table is flat, the grind is quite rough. The fence is pretty flimsy - plastic and aluminum channel.
Overall, the design is good, however it is quite apparent from the fit and finish that the machine was made in China. I might buy one again, but I would certainly look at the Steel City and Jet closely first. I have been shoving mine around on the floor of the shop but I will install a mobile base. I will probably build my own and extend the base out a few inches to insure a solid footing.
