Anyone used Rot Repair kits? (OT?)
>Several companies make kits for repairing rot. (I am generally opposed to these repairs and would prefer to replace the rotting wood, but in this case the cost may be excessive and the repair more reasonable.)
Some kits include a fungi killer, wood hardener, and epoxy putty to fill the rotted area.
Any experience here? Have your repairs been in place for several years? Does the rot re-occur or continue? How does the repair look/perform over time? What brand/technique did you use?
Re: Anyone used Rot Repair kits? (OT?)
David Yoho
>Barry, I haven't used one of those kits but I did do a repair on my outdoor shed that has worked well. I have a shed built by Heartland that had an area of rot at the bottom of the left side 2 x 4 that the left door is hinged on.
At first I thought about just replacing the 2 x 4 but the long continuous hinge for the door made it more of a job than I thought it was going to be. I decided to patch the area and I used Bondo I picked up at Lowe's. I cleaned and scraped away all the rotted wood, added some galvanized deck screws to give the Bondo something to grab on to, and filled the void little by little. Once it was built up above the wood's surface and dried I sanded it, primed it, and painted.
You can't see where the repair is and it's been fine now for several years. I don't know if this will work in your situation but it might be an option to consider.
David
Lee Schierer - McKean, PA
>I used a MinWax product a number of years ago that consisted of a wood hardener and a two part body putty type filler. It worked pretty well. ou fist had to remove the loose wood and as much of the rot as possible, then apply the hardener. Once the hardener dried you mixed up the putty and filled the void. The putty cured in a few hours and could be sanded and shaped like wood. As I recall the putty lasted longer than the wood that was adjacent to it. I suspect the repair would have lasted longer if the cause for the rot had also been cured. I was only able to fix that when I replaced the door and frame a few years later.
Lee
I've Used One
Mike Fitterling
>I've used one in a marine environment. IIRC the stuff I used was called "Git-Rot."
My sailboat had a deck stepped mast and under the deck in an arch athwartships was a wooden beam meant to distribute the load of the mast. This beam was between the fiberglass cabin liner and the deck so it was very hard to get at.
Someone before me had drilled a hole through the deck and through this beam to route an antennae wire and this is how the rot started. The beam was sagging in the middle where the mast was stepped. There is a lot of pressure in this area on a sailboat, as much as the full weight of the boat can be exerted on the step area. This was a 25 foot boat, weighing about 6,300 lbs, so the load was considerable.
I loosened all the shrouds and stays so that only the weight of the mast was resting on the step and mixed up and poured Git-Rot into the antennae hole. This stuff was epoxy based and was supposed to wick back into the surrounding wood fibres until it reached non-rotted wood, then harden and stiffen the area of rot.
After the curing period I put tension back on the step by tightening up the shrouds and stays, and I never had any more problems in this area. It did not remove much of the sag, but did stiffen the structure up when it had sprung back from the tension released on the stays, and when tensioned back up it stayed put, so the deck sag was lessened.
Of course, all this was done in a non-visible area. I do not know what the appearance of the stuff would be, but it certainly worked. I sailed thousands of miles on that sailboat in some very rough seas and winds and that deck step never gave me problems after the fix.
Cheers,
Mike
Kneale Brownson..Awaiting return to CO snows
>I didn't buy a kit, just a bottle of somebody's rotted wood hardener to fix a couple of exterior windowsills. I cleared away the rotted wood with scraping/drilling/picking with something like dental picks, etc., and brushed on a generous amount of the wood hardener maybe two or three times. The punky stuff did get harder. Then I just filled with wood filler, that stuff you mix a bit of powder into water to form a paste that hardens when it dries. A little filing and sanding and then a good coating with primer and paint and it's held up for years.
jfox442
>I used a product (don't remember exact name) form Bondo. Yep--the autobody-repair Bondo. Two-part...came in about a gallon size can. Said on the outside that it was to repair rotten wood. Got it at one of the Borgs.
Used it on the partly rotted base of a post that supported the corner of a patio cover. First pressure washed the bottom of the post then cleanded out ALL rotten wood (about half of the inside of the post was still good or else I'd have replaced the post). I put the "stuff" on in layers...adding layers as it hardened--had to work fast as it cures quickly. Then after it was built up I sanded it flush with the rest of the post, primed it and painted. Looked good as new.
James
Jerry Draper
>I have used a product called "Rot Fix" on 2 different occasions with good results. Just follow the instructions that accompany the product.
Can be purchased from Rockler.
Chicago Bob
>Lee,
Bondo & various 2 part epoxies all work quite well if you remove all traces of rot and cut out the rot area slightly past any visual rot. I learned the following steps from a guy would did this for a living:
1. cut / remove all evidence of rot/puncky wood, cutting slightly past the visible evidence.
2. spray the area with a dilute bleach solution until completly wet.
let this area dry in the sun for at least 1 day. must be dry.
3. using a damp rag, wipe the surface to remove any alkalinty from the bleach solution left on the surface. let dry until visiblely dry - maybe an hour or so.
4. apply bondo or epoxies and build the area slightly above its original profile. You may want to do this in layers if it is more than approx 1 1/2" deep for proper curing.
5. once cured, sand to obtain a smooth surface & original profile.
6. prime, dry, & 2 coats of original paint.
I had a number of windows repaired this way when I lived in very humid Charlotte, NC and it worked and looked great. THE ABSOLUTE KEY TO MAKING A PERMANENT REPAIR IS TO REMOVE ALL EVIDENCE OF BLACK MOLD BEFORE USING A FILLER. IF YOU DO NOT, THE MOLD SPORS WILL START MIGRATING INTO THE WOOD SURROUNDING THE REPAIR AREA AND START THE PROCESS ALL OVER AGAIN.
hope this helps because this problem can be a pain in the rear and in the case of windows, expensive.
regards
Bob
Jim Dillon
>Barry,
I've used both the epoxy "kits" intended for rot repair, and the general purpose Bondo in gallon quantity available from the Borg. Both will work, but the epoxy kits are very expensive, a factor to consider if you have a lot of rotten wood to repair. I ended up using the Bondo product for nearly all my window/sill repairs several years ago (16 windows), and so far it has held up well. As others have said, the key is getting all the rotten wood out and/or replacing the rotten wood with new primed (both sides) wood. I like the suggestion of using a bleach solution to do a final clean. Some WC folk in the past have raised the issue of potential water absorption by the Bondo, thus potentially shortening its service life. No sign of any problems so far with what I have done (knock-on-wood). Now, if I owned a wooden boat and my life might depend on the quality of the repair, I would likely use the epoxy repair kits. But for home-use, Bondo rocks. Hope this helps.
Jim
R Drouare
>If you go to ROTDOCTOR.COM you will find all the info you need to successfully do your repair. I have used their product and also the kit from Rockler for repairs with very good results. The auto body
"BONDO" product is also a good alternative. Which product you use is a matter of personal choice and availability. Happy repair to you.
Wow! Thanks, did not expect the response and...
>I may have to rethink my position. I was under the impression that the rot just continued and the hunk of Bondo/epoxy would fall out after a year or two. This may work better than I thought.
Did anyone have a bad experience?
Re: Wow! Thanks, did not expect the response and..
Jim Dillon
>Not yet, but I think your concern is a real one. I tried to make a judgement based on whether I could really scrape/pick/dig out all the soft wood that I figured was rotten, and get down to solid wood. If it looked like I was going to have to tear out nearly the entire window frame/sill in order to do that, I just ripped everything out and replaced the wood and filled with Bondo. Thankfully, that scenario turned out to be the exception, and I ended up mostly digging out the rotten wood and filling in with Bondo, plus maybe a few smaller pieces of good wood. Hey, if it only lasts 20 years, I sure am not going to be in a position to care ;-). I did use a good primer and exterior oil-based gloss trim paint to improve my long-term chances.
Jim
