Storage of flammable liquids?
wilbur
>My shop is in my basement. I have a few containers of flammable liquids in my shop -- the usual suspects: naphtha, mineral spirits, some finishes.
My recurring nightmare, especially after reading some recent posts on BLO soaked rags, is that somehow those liquids get ignited, which means that my shop, and therefore my house catches fire. So I'm looking for a way of sorting these containers. I know that there are special small cabinets for flammable liquids, but [1] I thought I'd see what other WC folks do, and [2] I don't really know where to start.
Thanks!
Re: Storage of flammable liquids?
>A couple of thoughts.
An old refrigerator.
A metal cabinet.
I use a metal cabinet that I have grounded.
Out doors . . .
steve mackay
>I have the same nightmare ! I'd feel REALLY stupid if there were a fire from this stuff. And no one to blame but me. I've got a "lean-too" kinda breezeway outside where its all stored. I know those cabinets are all fire rated and such but I try to NEVER shake my fist at God. He always manages to show me whos in charge. Why tempt him ?
Jason Roehl in Lafayette, IN
>I'd have a hard time storing flammable liquids in a basement shop. The main reason is simply that many of them have heavier-than-air vapors. I've heard of framers getting killed because they were using construction adhesive to glue down subfloor at ground level, when something sparked off the vapors that had off-gassed from the adhesive and collected in the basement.
I could see using them with adequate cross-ventilation during application and drying, but I wouldn't store them down there. Say one springs a leak (rusty bottom or something) overnight, then the furnace or water heater down there kicks on in the morning...
Jason
Dick Coers
>The vapor can migrate through the wood to wood joint and collect in a sufficient amount to explode? Even with squeeze out, they must have been really sloppy, like tubes and tubes of squeeze out. I'd like to read about that incident. Any links?
Re: Storage of flammable liquids? *LINK*
Jim Dillon
>Wilber,
I don't have quite your problem as my shop is in a detached garage. Still, I try to minimize the amount of flammables, and keep stuff in individual metal containers - usually the ones that the solvent comes in. From time-to-time, I have thought about getting a metal cabinet, but they are quite expensive. Yeah, I know, penny-wise, pound foolish or something like that. I am very, very cautious with finishing rags as they will indeed ignite spontaneously, as I once found out when I started woodworking. Put a bunch of used Danish Oil rags into a bucket then took the bucket out into the backyard and went to do something else. Came back several hours later and discovered a LOT of acrid smoke coming from the bucket, and as they say ... where there is smoke, there is fire... . Now I soak them in water and let them hang dry. Well, I digress. If my shop was under my house, I would find an old refrigerator or metal cabinet as JL suggested. Or scare up the cash to invest in a good cabinet, but still only keep the absolute minimum I needed. Maybe a small outside storage shed or something? Here is a link to a place that sells this stuff so you can see what is available. Their paper catalog is huge, and I have had good service from them for other stuff, just not chemical storage cabinets. Hope this helps a little.
Jim
Lab Safety Supplies
Bill Howatt
>Yes, it is a problem and a potential hazard storing the finishing materials but I think the big hazard is indeed spontaneous combustion.
I have an old metal shop vac cannister that the lid snaps on with 3 latches. I removed the vac motor from the lid and patched the holes with aluminium. I put in a large coffee can about 2/3 full of water into the cannister. Oily rags and whatever are put into the coffee can water bath and its plastic lid put on, then I put back the cannister's lid.
Ideally, the more stuff you can get out of the basement the better but sometimes it just isn't practical so be careful and be very methodical in getting the rags into the proper place whatever you decide that is for you. It is too easy to put a rag down and then forget about it.
Bill
>Here's a similar incident in the link below.
It's not necessarily the off-gassing through the joint, but I would suspect a large amount of the vapors come from the bead of adhesive before the two surfaces are mated. When laying subfloor, you're talking a LOT of adhesive...
Jason
Construction adhesive explosion
Dick Coers
>Thanks for the link, very interesting reading. I suspect those guys were getting loaded from the fumes. 35 tubes of adhesive in a nearly finished house, WOW!!!!! Maybe they should have just dumped over a 5 gal. bucket of contact adhesive to do that job!
I sometimes take the sceptical route on these stories, but with the perfect situation, anything can happen. I remember as a kid on the farm, we used gasoline for cleaning parts, paint brushes, and even our hands. I would be moron to do that now, but when your Dad tells you.........I used to think that my skin was a barrier too. Can't imagine the damage done to internals by washing with gas.
