OT: House framing, trusses & attic insulation
Luke Herzberg
>I have a question for the collective WC intellect.
What does the eave/top plate detail look like when using pre-fab trusses with tails with regard to blocking between trusses and ventilation baffles for the attic insulation. In this application, there will soffits framed separately off the truss tails. Thus, the distance from top plate to roof sheathing is only 3 1/2"+.
Would there typically be 2x4 blocking between each truss? The typical poly insulation baffles that would run in this hole will take up part of the space, allowing blocking of maybe 2 1/2" or less in height. Is shorter blocking, or blocking in every other space a common practice?
Thanks for any input.
