Pallet lumber`
Bill Tindall, E.TN
>Every hardwood mill generates lots of low grade lumber and it usually goes to a pallet factory nearby. It would be a simple matter to run the low grade cants through a gang rip set at 2" then turn the stack and run it back through, thereby generating 2 x 2 stacks XX feet long. The question is whether the mill would have the conveying system to return the gang ripped cant to rip the 2 x 2's. . Mills are designed to move lumber forward and less so to return it to an operation. The trim saw could even be set up to chop them to length.
I would suggest searching for a small to medium sized mill that might accommodate the job. A small mill would just do all the operations on the head saw and might be delighted to get the work. One would saw a stack of 2" lumber and just load it by hand back on the carriage to be sawed into the 2 x 2's. We sawed piling sticks this way. Lengths would be cut on the saw used to saw the slabs into firewood which are about 2' pieces.
My guess is that the labor to handle the pieces would be greater than the cost of the lumber. They would have to be stacked and banded by hand I suppose. The stakes will by in large be heartwood and molding not much of an issue.
