Warped Teak table top ..I Need
Rich Pearson in Mill Creek, WA
>Your suggetions on how to best flatten. My son and daughteer-in-law bought a teak table of asian origin. Naturally with the different humidity in Seattle, it warped mightily!
Each panel is 36" wide by 30" deep. The shaped runners which allow for the insertion of an extra leaf (Pix2) were screwed and glued to the table top panels. Each panel is a glue-up of 4 boards and the total deflection, measured mid panel is 3/8" over the 30" span.
I plan to rip the panel along the glue lines and re-assemble, provided that takes most of the bow out of it. I might have to rip each of the original 4 boards in half again and then thickness sand (on my Performax 16/32) LIGHTLY to flatten them.
Flipping the boards to alternate the end grain is not an option as the bad side (underside of the table) of the wood is really bad and has many patches and skip planing marks.
I am trying to preserve as much thickness as possible as each board is 7/8" (shy) thick.
(1) Am I on the right track?
(2) When flattening with my Performax, do I sand the board "crown" side up or "crown" side down first. (I am leaning to sanding the "crown" side up until that side is flattened.
OR ... has any one done this and have another approach?
I will make new runners and attach them with slotted holes and no glue to allow for movement.
Thanks!
Re: Warped Teak table top ..I Need
Here's what I'd suggest
>My first reaction would be to release the table top from its constraints. If those cleats are actually screwed and glued to the undersides of the top, that is most likely the problem right there. I'd remove the cleats, sticker the tops and let the wood come to equilibrium for a few days or a week or two. Use cauls and weights to persuade the panels to flatten out, then use cleats creatively to adjust the flatness.
What I mean by that is to start with cleats that are strong enough from a beam perspective that if you clamp the cupped top flat onto the cleats, they will overcome the cupping forces. (Remember Charles Atlas and Dynamic Tension?) The smallish cleats you have there at the moment may not be sturdy enough to use as beams.
Crown the beams with a nice gentle radius -- just 1/4" or so at each end -- then secure them to the underside with a single screw in the center and screws at the ends in slotted holes, to allow for the top's expansion and contraction. That should do it. Across a 30" width, you could use five screws, but be sure to allow for wood movement.
I have used this technique many times with good success. I'd definitely try it before ripping the top and re-gluing. Odds are, it was flat once, and it will want to return to that state once you get rid of those cleats.
Lee Grindinger
What the warping says
Lee Grindinger
>The wood in your top has shrunk. It's not surprising considering it's origin in Asia. The surface of the cleat against the boards of the top is shorter than the surface not attached to the boards.
I'm with Ellis, knock the cleats off and let the top go where it wants. I'm not sure it will return entirely to flat but new cleats should do the trick. Since there probably has been some wood tissue damage, fibers being compressed on one side, stretched on the other, it may work to moisten the shortest surface after it's rested for a couple weeks without the cleats.
Good luck, don't saw it yet,
Leew
If you are planning to refinish.....
Howard Acheson
>... I would suggest you chemically strip the finish before attempting to flatten the panel. There looks to be a rather thick film from prior finishing and that film will significantly slow up water vapor (moisture) transfer. What you really want to accomplish is the equalize the moisture content on both the top and the bottom surfaces of the panel.
If the table has been outdoors and/or if it has been warped for a long time, it may not flatten with the above process. The cell structure of wood becomes permanently deformed after an extended period and adding or subtracting moisture may not cause it to change. If that is the case, your best bet is to attempt ripping at the gluelines, jointing to 90 degrees and regluing. Keep in mind that ripping and jointing will result in a narrower table.
If there is some residual cupping, I have used some 3/4" x 3/4" or 1" x 1" angle iron screwed to the bottom. Drill slotted holes in the angle iron. Between the angle iron and the new cross cleats, it should bring the table into flat. It will also be pretty heavy.
Re: Warped Teak table top .THANK YOU!
>Thanks to all for your suggestions. I will re-rip the table top only as a last resort.
The "clamping caul" suggestion along with metal supports is an approach I will try.
Both panels currently have heavy toolboxes on top to start the flattening process.
Thanks again!
