Questions on 1878 U.S. Gov't. specifications
Ray Newman
>Gents: I have 2 question for you.
I am reading through a copy of U.S. "Ordnance Memorandum No. 21" (1878). Secifications for wood packing boxes for .45-70- 405 (rifle) & 45-55-405 (carbine) service ammunition, says:
"Boxes are made from red-knot white-pine boards, planed both sides 15/16 inch thick, corners halved together and secured with glue."
What are "red-knot white pine" & corners "halved together"??
Re: Questions on 1878 U.S. Gov't. specifications
Fred Davis
>Red knot Pine refers to a tree that is living when it is felled for lumber.
The knots are red and stay tight.
Trees that are dead when felled have gray knots and the knots are loose or will be.
any wood ammunition box I have seen had finger joint or "box joint corners.
FredD
steve mackay
>Small arms ammo boxes are made to "un-roll" from around the actual ammo container. Each side of the shipping box corner is one half of the corner. Once the wooden container is glued around the ammo cantainer it gets wired around the whole. This method did'nt come about 'till self contained ammo though. The carbines and such around the end of the civil war. Still the standard today. I drop the box on the ground to break the glued "half-corners", cut the wire and unroll the wood "box". Now all I've got is the familiar green "ammo-can" everyone knows and loves.
Fred Davis
>Take a look at
www.saylerscreekrelics.com
under accoutremnets , you will see some civil war wood ammunition boxes with dovetail corners , what can I tell you ;-))
FredD
Warren in Lancaster, PA
>It is true that red knots are tight and black knots are loose, but you can often see both on the same board. A black knot occurs when the tree grows around a dead branch. Dead lower branches persist on white pine trees and the tree grows around them forming black knots until the branch rots off or breaks off. Then the tree can heal over where the branch was.
Ray Newman
>Fred Davis: the box you linked me to is for the .577 Enfield service rifle, which the CSA imported in large numbers. My hunch is that it is English made. But, I've also seen original US .58 calibre musket ammunition boxes w/ dovetails & I read US Gov't. specs. requiring dovetail corners.
I did find a picture of a 1873 1000 round .50-70 Gov't. US ammunition box, w/ a screwed on lid & rabbet joints for the corners .
http://www.oldammo.com/may04.htm
My hunch is that rabbet joints were on the 1878 boxes. Anyway, I ordered another book, which supposedly goes into more detail.
Steve MacKay, I don�t think that these were made to �unroll�, or packed or shipped in larger quantities, like a pallet, etc. I think this is what you are referring to?? I�ve seen ammunition palletized & shipped that way or 4(?) metal cans held together by a wired �crate�.
A box of 1000 .45-70 or .50-70 cartridges weighed approx. 107 lbs. The US Ordnance Dept. 1878 memo does not mention any wire reinforcing for these boxes or packing in in bulk, etc. Ea. wooden box contained 50 pasteboard boxes w/ 20 rounds ea. The box tops & bottoms were screwed on w/ 2� #13 screws & cut nails reinforced the glued corners. Per the 1878 memo, boxes for the 1� Gatling rounds did not have any metal straps or wire reinforcing.
I have read accounts & seen photos of ammunition carriers -- 2 men to a box -- re-supplying US Army units w/ .45-70 ammunition packed in such wooden boxes & transported by mules during the Philippine War (circa 1900).
I was surprised that the lids were screwed on. �Best-better� not loose your screw driver??? Plus 15/16� thick material is rather stout & might take more than a few blows for the butt plate to break it open. During the Zulu War @ Isandhlwana, the British allegedly ran into problems trying to open screwed on ammunition boxes.
As an aside, besides the ubiquitous hinged & removable top @WW II (& later) GI metal can, the US also packaged .45 ACP & 30 cal. M1 carbine ammunition in �spam� cans. The cans looked liked a ham or spam loaf metal can w/ a key to break & roll up the seal. I saw more than a few such cans in Vietnam & @ my friend�s gun shop when he sold some WW II surplus ammunition in the 1980�s. I�ve also seen early 1900�s wood ammunition boxes w/ box joint corners.
