Veritas - Innovation in Tools
OT Glue type question
Sawman
>My wife has a few broken piecs of ceramic pieces that need parts re-glued. What type of glue would hold?
Thanks
Re: OT Glue type question
I've had luck with epoxy
>Use the 2-ton variety or West System though. Five-minute epoxy doesn't cure hard or strong enough.
Cyanoacrylate might be a good choice
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>It has the advantage of being able to cure quickly with the activator, which I find desirable for things that are hard to clamp, and can only be hand held.
It does take a little practice to get accustomed to.
Re: Cyanoacrylate might be a good choice
Norman
>About the CA activator...
Just wet your finger and run it along the glue seam, this is essentially what the expensive activator does. Found out about this trick when I used to build R/C planes many years ago.
Norman
CA and moisture
GolfSteve in Calgary
>CA glue works great for gluing ceramic back together.
One tip - around here the climate is so dry that CA sometimes does not grab. CA requires moisture to cure, and I've had trouble with CA glue until I started to add a bit of moisture.
What I do is slighly moisten one side, apply CA glue to the other side, then hold the pieces together for about a minute.
Robert R. Clough - Thorncraft
>I've used Duco Cement and its predecessors for over 40 years. So far, so good. Easy to use and quick to set. Cleans up with nail polish remover (Acetone).
Re: OT Glue type-This works
Dave Anderson (PacNW)
>use "Titebond Melamine Glue" this glue is amazing it will bond ceramic like nothing else and dries crystal clear. My wife uses it all the time with her ceramics and you thought wood working was expensive as a hobby.
Dave(PacNW)
John L. Blue
>Goop!
