Re: Steamer------WebKitFormBoundaryg+m7FR5DZbDCiSb
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>That looks pretty good. You should be able to get a lot of parts in there at once. Do you do multiple parts at once?
If you plan to use it in winter, even though it is wood, which is a poor conductor, I would still find a way to insulate it. Steaming is all about getting the wood up around 210� all of the way through. Any heat loss through the walls are wasted BTU's, which makes it take longer.
I have a food thermometer inserted through a hole in mine to monitor the temp in the end of the chamber. But, I have also been thinking about getting one of those which can be inserted into the middle of a thick piece of meat, to insert into a hole drilled into the wood. This would give more accurate information than just going by an hour per inch of thickness.
------WebKitFormBoundaryg+m7FR5DZbDCiSb9
